Home > Technical > MAF issue one week out of warranty
Page 2 of 3 <123>
Replacement will likely solve it completely. I doubt there is anything else that could be wrong unless there is a damaged wire / cable but highly un-likely I'd have thought. Like the EGR most of these items have a serviceable life and they eventually give up and there isn't much if anything you can do with them. Probably not what you wanted to hear but I bet once replaced you'll be utterly problem free. Thumbs Up _\Hennessey|Venom| F5/___
___\â­ï¸Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #181672 3rd Nov 2012 4:58pm
Also bearing in mind that an EGR with issues can also put the MAF readings out and flag up a MAF fault even though there is no MAF issue only with the EGR playing up causing wrong readings.. I had this happen. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #181674 3rd Nov 2012 5:00pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
So are you saying I should replace the MAF, the EGR valve or both?
Post #181679 3rd Nov 2012 5:10pm
What I'm trying to say is: If your EGR has fault(s) it can sometimes affect the MAF sensor. So if this is the case I would replace the EGR first and leave the MAF. Clear the DTC's and go from there. Worst case scenario is you'll get a MAF DTC again of which then you'll have to replace that too. OR like with me I had both EGR and MAF codes coming up on the system however on good advice I replaced the EGR only and cleared all codes & never touched or replaced the MAF sensor and to this day NO codes or MIL at all. Hope this makes sense..
Steve
____/🇬🇧🇺🇸\____
Post #181686 3rd Nov 2012 5:34pm
kmac
Thanks thats clear now.....thinking of putting in one of those EGR blanking plates.
Post #181690 3rd Nov 2012 5:38pm
You could indeed. If replacing the EGR it's an ideal time to do it. Thumbs Up
EGR removed:
____/🇬🇧🇺🇸\____
Post #181692 3rd Nov 2012 5:40pm
kmac
Why would I need to replace the valve if i'm going to fit a blanking plate?
Post #181696 3rd Nov 2012 5:47pm
Because if your current EGR valve is throwing up DTC's it will still do it blanked or not. So you'd have to fit a new EGR and whilst at it you may as well fit a blank. I could have done with mine but I was more interested in just getting the MIL off and EGR working. Regarding blanking plates there is whole threads on the subject on here. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #181699 3rd Nov 2012 5:52pm
Info on blanks can be found here in places: a 12mm hole in the blank was a good rough guide.
http://www.defender2.net/forum/topic2227.html _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #181707 3rd Nov 2012 5:57pm
kmac
Thanks, will monitor it and try and narrow down where the fault is. EGR valve seems to be circa £125 where a new MAF is about £40
Post #181716 3rd Nov 2012 6:05pm
I know a Pain in the a... it is. I luckily managed to get the last of the old stock EGR's at £92 but I was lucky they went up to the price you mention just in the last 6 weeks / month. Neutral _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
Post #181717 3rd Nov 2012 6:08pm
Lorryman100
kmac wrote:
Ok damn MIL came on again. Nanocom came up with the following:
NANOCOM - PUMAENG.APP - PUMA ENGINE fault file
167B - 41
Fuel injector learning not done
missing CAN signal high/low switch
0100 - 64
Mass or volume air flow A circuit
signal plausibility failure
0404 - 72
Exhaust gas recirculation (EGR) control circuit
range/performance
actuator stuck open
0299 - 00
Turbocharger A under boost condition
0234 - 00
Turbocharger A over boost condition
I note the MAF error still there - may try replacing the MAf - however it refers to the circuit rather than the sensor itself
Also anything I can do re EGR actuator being stuck open?
The above DTC's are common untested DTC's with the exception of
167B - 41
How does the Puma run at tickover and does it feel lumpy at low revs? Below is a copy of some DTC's that log often on my Puma without the MIL lighting.
0404 - 72
range/performance
actuator stuck open
0299 - 00
1103 - 00
Mass air flow (MAF) sensor in range but
higher than expected
0404 - 73
range/performance
actuator stuck closed
0234 - 00
1402 - 17
valve metering orifice restricted
circuit voltage above threshold
The first thing I would do is clear the faults and then start the engine and go for a two minute drive. Then recheck for any DTC's that are logged. If P167B - 41 is relogged then have a pilot correction learn done. As to the MAF sensor, at £35 I would just replace it and coat the plug in electrical contact cleaner before connecting. If the EGR is not noisy and you can hear the 5 x chukka chukkas at shut down then I would say there isn't an issue with the EGR. If the EGR valve takes longer to open than the stored values within the Fuel file in the EMS then it will log a untested DTC (No Mil) then after 40 consecutive driving cycles without the fault reoccurring the DTC will be cleared. If the EGR fails the self test cycle then it will log a tested DTC. The problem with the nanocom is that it logs both types without differentiating between the two which does lead owners to be convinced that a part is faulty when it is fine. Only time spent monitoring the Puma over a few weeks will give you a feel of what to ignore and what is the problem. I have an IDS system as well and the fast idle test would tell me straight away if the MAF or EGR was at fault so if it is still in warranty get it into the dealers to fix. Thumbs Up
HTH Brian.
Post #181726 3rd Nov 2012 6:48pm
kmac
" If P167B - 41 is relogged then have a pilot correction learn done" eer what's that and how do I do that please?
Did feel a bit rough at low revs.
Went for a drive, will check now if the faults re-occur
Sadly as per title of thread was only one week out of warranty when issues came up
Post #181739 3rd Nov 2012 7:29pm
kmac
167B - 41
0100 - 64
0404 - 73
range/performance
MIL came on again
Post #181745 3rd Nov 2012 7:41pm
Lorryman100
How is the EGR sounding, does it do the 5 x chukka chukkas at shutdown? Can you hear strange scrapping sounds when driving? If you could answer these questions first to discount the EGR as the problem, as the last DTC said the valve was stuck open!
That then leaves two issues logged in the EMS. The first is the injector re learn or pilot correction learn, there is a 16 digit hex code printed on each injector. These are the machined tolerances of that particular injector. Machining tools wear with use and the tolerances on an injector are tight so the hex code tells the EMS the particular tolerances for that injector e.g. opening times, shutting times and these injector characteristics vary with fuel rail pressure. The process allows the EMS to learn these injectors, the EMS learns in increments to get the correct values to get the engine firing smoothly. The nanocom is not capable of doing this so you will need a dealer level diagnostic tool to do this properly ie: BBS MSV2, IDS, Omitec, Autologic or Symptom Driven Diagnostic (SDD).
I would change the MAF first as it is the cheapest part and will discount that being the problem DTC. I would also be putting a DMM on the female plug to check voltages to ensure it is not a wiring issue (the Puma electrical diagram gives outputs/inputs voltages for the MAF on the EMS side).
HTH Brian.
Post #182037 4th Nov 2012 7:00pm
Page 2 of 3 <123>
