Home > For Sale & Wanted > SVX headlamps
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
SVX headlamps
Has i've upgraded most of the fleet to LED headlights, i have a set of the SVX headlamps ........£45 p+p Putting Dreams on Drives at JLR Solihull..
Post #176205 16th Oct 2012 11:18am
Bodsy
Re: SVX headlamps
I assume they come with the bulbs? If so I'll take them. Will pm you my address. Thumbs Up
Ian Over on D3
Post #176209 16th Oct 2012 11:27am
adafish
yep....DONE Putting Dreams on Drives at JLR Solihull..
Post #176220 16th Oct 2012 12:06pm
Bodsy
These 80/100 bulbs, is it ok with std wiring or do I need to rewire with a relay?
300tdi 96 csw Over on D3
Post #181647 3rd Nov 2012 1:49pm
ericvv
The light switch already often melts with the standard 55/60W H4's, so imagine 80/100W Shocked
80/100W H4 in main headlamps, with relay or not, they will be not road legal You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #181651 3rd Nov 2012 2:41pm
adafish
sorry fella, only just seen this post, was'nt aware the bulbs were that wattage..... Putting Dreams on Drives at JLR Solihull..
Post #181949 4th Nov 2012 1:19pm
leeds
Maybe not road legal in Switzerland but UK Vehicle Lighting Regulations states
Quote:
8. Wattage–
(a) A motor vehicle, other than a solo motor bicycle or motor bicycle combination, first used on or after 1st April 1986:
No requirement
(b) A motor vehicle, other than a solo motor bicycle or a motor bicycle combination, first used before 1st April 1986:
30 watts minimum
(c) A solo motor bicycle and a motor bicycle combination–
(i)having an engine not exceeding 250 cc: 15 watts minimum
(ii)having an engine exceeding 250 cc: 30 watts minimum
9. Intensity:
No requirement
Personally I think there should be requirements with a minimum and maximum light output as wattage has nothing to do with light output but is a measure of electrical power consumed!
Brendan
Post #181967 4th Nov 2012 2:17pm
