Home > Puma (Tdci) > strange plug under center tray
Page 3 of 3 <123
TBH the set up does not look good for a proper Sub Whistle
Post #181357 2nd Nov 2012 5:26pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
ken, i was also thinking that, at only 150w and no size to the enclosure there wont be much base.
but i am no trying to think how i could use these for my install... problem is the amp is hopefully going in the battery compartment...
thanks for all the help and links Japseroony
Post #181414 2nd Nov 2012 8:15pm
If you have a bulkhead and don't need the space you could always fit an amp there? Don't be surprised in the seatbox if it doesn't get filthy and maybe even rust a bit. Shocked found this out the hard way under my drivers seat.
I'd have also though they could of came up with a better solution than sticking the amp on the back of the cubby. Granted there is limited room but that is the lazy solution imho. Plus you won't be able to see it have hardly any access without pulling it all out or indeed even adjust it. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #181427 2nd Nov 2012 8:39pm
dgardel
Italy
Re: strange plug under center tray
.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #181433 2nd Nov 2012 8:44pm
chadjizz
dgardel, sorry you have lost me???
custom90steve, mate i would but its a 130 double cab so you would see it and i hate wires everywhere. plus not putting it under the back seats as they are coming out so the Labradors have a massive flattish bed. you have now got me worried about putting in the battery cubby now!
Post #181461 2nd Nov 2012 9:14pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Seal up the battery box thoroughly, there is also room under the drivers seat, i usually fit an air compressor there. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #181463 2nd Nov 2012 9:18pm
Sorry, I mention this because my Head Unit has an external control unit which I used to mount in the seat box under the drivers seat until one day had a look at in many months later and found it rusting. Shocked Needless to say it's now mounted behind the drivers seat. Might help to seal the seat boxes though. ____\We|Will|Win/___
Post #181464 2nd Nov 2012 9:19pm
willy eckerslike
It's good thing to point out Thumbs Up the seat boxes often leak Original Member Pie n Pea Club.
110 HCPU Tipper
Post #181465 2nd Nov 2012 9:20pm
I think it's the corner seams that do it. Nothing a bit of silicone wouldn't sort. So long as condensation or damp doesn't become an issue instead. ____\We|Will|Win/___
Post #181466 2nd Nov 2012 9:23pm
chadjizz
will make sure i seal it then, thank you for the advice.
its going to be a tight fit, i hope it fits.... Confused
Post #181503 2nd Nov 2012 10:40pm
dgardel
Italy
I wrote an uncorrected infos.....
sorry Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #181543 3rd Nov 2012 12:49am
Page 3 of 3 <123
