Home > Maintenance & Modifications > Side Exit Exhaust on a TDCI 110
ellebarto
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I know a lot of people have done this but my mate is a mechanic and always said he could do mine really easily reusing most of the current rear section. I've already decatted and removed the centre box so the sound is right for me and I just wanted to lift the exhaust a bit and tuck it away.
I was dead impressed with the way he did this for me and it cost virtually nothing!
Post #181257 2nd Nov 2012 11:48am
Very neat mate Thumbs Up
Post #181261 2nd Nov 2012 12:06pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
got one here i don't need...Was made by Porny, with a something a bit special has the tail end pipe.... Putting Dreams on Drives at JLR Solihull..
Post #181306 2nd Nov 2012 2:39pm
ellebarto
What's that mate?
Post #181314 2nd Nov 2012 3:10pm
df1
Something about those side exit exhausts always baffled me, with the exhaust suspended on rubbers does the exit not restrict this movement ?
Post #181345 2nd Nov 2012 4:43pm
Nope Whistle
Post #181347 2nd Nov 2012 4:50pm
ellebarto
I'm not sure I quite understand what you mean. There is virtually no movement in the exhaust in its original position.
Its bolted to the centre pipe securely and then using the original rubber mount point it has a bracket connecting it. There is fractional movement within the hole we have cut out but only fractional. There is probably about 3/4" clearance around the end of the exhaust where it exits so it can vibrate to some extent without touching the hole!
Post #181350 2nd Nov 2012 4:54pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I was wondering exactly the same but that's a clear explanation - theres a bit of movement but the hole is big enough to allow it.
Looks like a good neat job
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #181352 2nd Nov 2012 5:04pm
ellebarto
DJ
Yeah part of the reason we did a lot of tack welding in situ was to get that central exit position. There's enough weird rattles and vibrations in a defender without adding to them! Very Happy
Post #181353 2nd Nov 2012 5:06pm
Had a twisted SE on the 2.4 never again looks great sounds great
However no fookin good when you want to use an air Jack Rolling with laughter
Post #181355 2nd Nov 2012 5:21pm
df1
Makes sense now ellebarto, thanks for the info, I presumed it was a rigid connection at the exit point.
Post #181498 2nd Nov 2012 10:31pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Defender 110 TDCI Side Exhaust
Hi fellas;
Reviving an old thread, but I’m really interested in fitting a side exhaust to my 2012 110.
My vehicle is in the final throws of its LS3 6.2 litre and 6 Speed auto installation.
Apart from interference with air bag jacks, are there any other cons to this mod?
I’m only fitting as a cosmetic mod, but the vehicle does get heavy off road use in Australia.
Thanks for any advice re this and best wishes all.
Ken
[/img]
Post #834750 2nd Jun 2020 10:00am
