Home > Maintenance & Modifications > Before the god of ice takes care of my fuel filler cap
Page 1 of 3 123>
Kraut
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
After having had a lot of problems opening my fuel filler cap during the last winter times due to rust, sand grains from green-laning and especially ice I wondered if there was any excellent aftermarket replacement for a Puma which is a little bit better when it comes to water- and dustproofness than the original one. Tried WD40, Oil, Antifreeze....., but already had to replace it two times after making it openable with hammer and screwdriver at -20°C with freezed fingers
Post #181212 2nd Nov 2012 8:40am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
What about a Defendoor?
http://www.defendoor.co.uk/
Obviously I have no experience with frozen fuel caps here in Africa........ Whistle
Post #181219 2nd Nov 2012 9:00am
Kraut
I was thinking of purchasing one of those, but only as a second-best solution. They don't look too good and I heard they are getting stolen quite often
Post #181222 2nd Nov 2012 9:12am
Regard
Stolen.....you serious?
Mine has been on my Defender for 6 months now and haven't been knicked yet, EVEN IN AFRICA Rolling with laughter
Really do not look bad and you can customize as you please.
Is the problem the water/snow/ice that "blocks" the cap or is more due to the temprature below freez point?
If it is due to temps I do not think it will help but if it is due to water/ice ingress I am sure it will help somewhat?
Post #181224 2nd Nov 2012 9:22am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Just ordered one - will let you know what it's like. 2007 TD5 90 Hard Top
Post #181225 2nd Nov 2012 9:27am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Me too
I was thinking of attaching a loop like on the fuel cap to the defendoor to stop leaving behind Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #181229 2nd Nov 2012 9:50am
Kraut
Thanks for the advise mates!
There is a nice upgrade-kit available, but because of my limited technical abilities I was looking for a simple cap-replacement with an adequate sealed lock that prevents diffusing the moisture or dust to the inside, so the lock could not be blocked anymore. Maybe anyone found a cap from another car-manufacturer to fit the puma!?
http://shop.ex-tec.de/product_info.php?products_id=184
Post #181232 2nd Nov 2012 10:01am
K9F
Thumbs Up ^^^^^^^^^^^^ Thumbs Up
http://www.defender2.net/forum/topic11700....=defendoor If you go through life with your head in the sand....all people will see is an ar5e!!
Post #181234 2nd Nov 2012 10:20am
Your more likely to leave a Defendoor behind than have it nicked. Guess how I know. My excuse was I was being rushed at the pumps. Embarassed All he same even if you do loose one they cost very little indeed to replace. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #181248 2nd Nov 2012 11:22am
Landlord
Been caught out once before, arrived at a service station early one Saturday morning on the way to some green lanes in Wales. Nearly out of fuel, couldn't get the fuel cap off. Spent the next 15 minutes anxiously battering the lock with a hammer and screwdriver ! Eventually got it off and was able to reuse but not lock.
Lesson learnt keep well oiled or cover the lock on the cap Thumbs Up 2007 TD5 90 Hard Top
Post #181254 2nd Nov 2012 11:40am
Kraut
That' exact what happened to me, only the second time it took more than half an hour hammering onto this Censored piece while screaming at it until it opend, must have been quite strange for the other people at the gas station. At that point I already had hands what felt like having second-degree frostbites. And I really had put a lot of oil in it after the first lock-desaster, therefore there must be another strategy for this years winter!
Post #181292 2nd Nov 2012 1:54pm
MartinK
This looks awesome!
We need a UK seller (Forum Sponsor) for one of these or something similar Thumbs Up
Brendan? Andrew (Defenderbits)? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #181303 2nd Nov 2012 2:13pm
farmer giles
don't forget that fresh human urine is very good at de-icing!
more a skill for the boys in directing it where you want it Very Happy
Post #181336 2nd Nov 2012 3:57pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
A tip I was given Is in addition to the defender door put an old oily rag on top of the filler cap this helps to prevent moister getting into the cap and freezing.
Jason.
Post #181348 2nd Nov 2012 4:52pm
FG - Yeah until it get's into the fuel system / tank. Try explaining that one. Rolling with laughter ____\We|Will|Win/___
Post #181358 2nd Nov 2012 5:35pm
Page 1 of 3 123>
