![]() | Home > Puma (Tdci) > Tow Ball on NAS rear Step |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Tow ball high with the NAS rear step, is the reason a few members on here have got rid of the step,, and fitted a proper adjustable tow bracket !!
Do a search, has been a couple of threads about it, along with some iffy pictures ![]() Main Brian James Trailer Dealer for South West UK |
All sorted now Tj
![]() ![]() Main Brian James Trailer Dealer for South West UK |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
If you have a step with holes in it for a 50mm ball it's not a NAS step. The NAS version has a reciever.
Nickwill Member Since: 19 Oct 2012 Location: Cornwall Posts: 22 ![]() ![]() ![]() |
No snags, many people seem to use NAS in the description, how about calling it the rear step bumper (VPLDP0095) then if this helps. |
Took your advice Tj ![]() ![]() |
Hi Fekete, I see on another topic where you posted a piccie of your rear end !! you are using a drop plate. Can you help with the queries in my original post please? |
"Hi Fekete, I see on another topic where you posted a piccie of your rear end !!"
Thank god I missed that particular post ![]() 110 HCPU Tipper |
![]() ![]() Only for Alison's eye Pete ![]() |
Hi,, You may gather, Fekete has now changed his towing equipment, I presume to get rid of the "drop plate" arrangement The problem is, with a plate on a "NAS Style" ![]() The "plate/towball" would need at least some sort of bracing, leading from the bottom, back to the chassis rails,, While i would love a step bar on mine, its of no use to me, as it spends 90% of the time when not aboard towing , with various heights of trailer hitches, i have to have the genuine slider/adjustable tow bracket California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
