Home > Technical > 3.5 V8 Timing marks
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
3.5 V8 Timing marks
Hi everyone.
I am trying to make sure my timing is adjusted on the 3.5 L V8 in my 110.
The manual says 5" to 7deg B.T.D.C.
I have these marks on the pulley wheel and with my timing light it is coming in right at the last mark BTDC.
My problem is that it runs perfectly at idle but when I go to drive it the power is on and off the whole time.
Thoughts, opinions, ideas?
Thanks
Tim
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #177842 21st Oct 2012 10:19pm
JWL
Is that not the symptoms of a problem with the vacuum advance and retard? Could be the distributor is not moving freely enabling the points to vary with load/speed.
Post #177849 21st Oct 2012 10:39pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi,
I don't have experience of a V8 but a long time ago I had a Ford Anglia that I could set the timing accurately using a static method but it would be almost undrivable and using a timing light it was all over the place. Eventually found it was a hole in the pipe to the vacuum advance retard on the distributor. Often these pipes may be all rubber or metal with rubber connections which perish with time. Worth checking first. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #177869 22nd Oct 2012 12:13am
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
If i remember corectly disconect the advance and retard rubber pipe or you will never get a proper reading you lightly undo the bolt holding the fork thing holding the distributor start her up and while using the timing light move the distributor one way or the other and you should be advancing or retarding the timing when its where you want it just pinch back up the bolt
Connect adv and retard and you should be good to go
Obviously all the above is from memory i could be wrong
Post #178116 22nd Oct 2012 9:39pm
speedymarktd6
What carbs do you have
Post #178118 22nd Oct 2012 9:41pm
WelshGas
Correct Speedymarktd6. That's how I remember doing the timing on my 4 cylinder engine. I would seal the pipe to the engine otherwise you entrained air and alter the mixture ratio. Thumbs Up LANDYWATCH
Post #178124 22nd Oct 2012 10:00pm
Timo
Thanks for the feedbak guys. Someone posted on another site that the timing marks are 3deg each. If this is correct then my timing should be about 12-15 BTDC which is way off
Does anyone know what the timing marks are?
Tim Series II in pieces
Post #179652 28th Oct 2012 2:07am
chris h
United Kingdom 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I did this on the V8 in my Morgan. Apparently the timing marks on Rover V8's are notorious for being in the wrong place! Mine was a 1978 and they were indeed incorrect, so I checked using cylinder no 1 and successfully reset the timing. I can't remember the exact details, but google it and you will find details. 2009 110 SVX 60th Anniversary - Santorini Black
Post #180162 29th Oct 2012 8:10pm
noworries4x4
A better timing light will calculate the degrees for you and show it on the gun, V8 distributors are renound for weak advance springs on the rotating counterweights under the contact plate, basicly means the distributor advances to fast instead of slowly 15 or 16 deg at 4,000 revs. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #180166 29th Oct 2012 8:18pm
