![]() | Home > Puma (Tdci) > F...ing edited... I'm a little surprised - should I be ? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Same as mine - By the end of the warranty it had....
Replacement engine 2 ECU's Clutch Steering box Air con compressor ![]() As well as a few minor repairs [Swivel seals, another Air con fault, couple of electrical issues] That lot totals about 10k or so inc labour !! Guns and Landrovers .... anything else is irrelevant. |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Which main dealer did your warranty work?
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6341 ![]() ![]() ![]() |
how comes the engine got replaced?
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
You need to remove any electrical mods incase they do updates on the car that could affect it. Pete |
Everything done by Guy Salmon's at Thames Ditton ............ couldnt fault them, fantastic service, great communication and good after repair contact ![]() |
Mine was one of the first batch for sale ... which alas had a machining fault on a oilway in the head [lack of oil feed to cam resulting in premature wear and distinctive clatter] LR replaced all engines complete rather than repair .... mine was done with 200 miles on the clock ! ![]() |
dave-h
aha - thanks. will call in tomoz first thing to swap over the 'mod' |
a bit embarassing calling into dealers .....
popping bonnet and taking the engine apart (well swapping a small part of it).... salesman who knows what the issue is suggested while the bonnet was up that I swap the gearbox ![]() hopefully get an update tomorrow. got a freeland hse and its doing less MPG than the defender !!!! ![]() |
just had a call from the dealer to tell me its the clutch thats gone.
not had a clutch fail on me before but I thought this was more gearbox, transfer box or differential than clutch? any thoughts? |
Think this was it? ... though this one is dated 21st july 08, mine was done in june 08
Land Rover Service Bulletin SSM38792, 2.4 Puma Engine Knock Noise. Title: 2.4 Puma Engine Knock Noise. Type: LD - Defender - All Years - Special Service Messages - Engine Name / Part No: SSM38792 Info Type: Service Bulletins Version No: 1 Date Uploaded: 21 Jul 2008 Models: LD - Defender Title: 2.4 Puma Engine Knock Noise. Last Modified: 21-JUL-2008 09:44 Category: Engine Symptom: 497000 Engine Noise Content Issue: Heavy audible knocking heard on start up. Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur. Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used. This condition will not occur on vehicles post assured Vin# 9A767162. Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed. Effects a batch of engines fitted before July .... check your vin ![]() |
