![]() | Home > Maintenance & Modifications > Flexi Radio Aerial. |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Combine it with your CB, works fine:
Click image to enlarge http://www.4x4cb.com/public/item.cfm?itemID=829 It's the little box by the CB. Merlin[/url][/url] |
| Thud Member Since: 21 Jul 2012 Location: London Posts: 667
First dibs are most definitely mine. I asked first and it's my thread. So there! The rest of you are losers weepers. |
Yay! Well done Brendan.
Received my Entreq flexi aerial today from Leeds and got it fitted in about an hour. No need for taking out the full dash or slicing in with the old cable to avoid the woes of threading through the bulkhead.
My fitting instructions: 1. Cut off old aerial at base. 2.Get access by removing wing blanking plate. 3. Pull out old aerial housing from inside wing and pull out through top of wing port. 4. Cut off from cable. 5. Tape new cable to old. I did ten inches. 6. Remove radio and unplug aerial. 7. Pull cable though bulkhead slowly. Use a gob of Vaseline where the lumpy bit is to ease it though the big rubber grommet. 8. Voila! Untape, plug up and put the new aerial socket together. I added a thick foam sleeve on the cable where it lies in the engine bay to help with interference. It sounds much better and there is no sudden interference/shash when the AC goes on. Click image to enlarge |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Close up picture of the base please Thud
Thank you
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Did you need the picture to see if theres enough room to put some leather on there?
Now there's a thought
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Thud,
Well done and thank you for the clear instructions! Not had the opportunity to fit mine yet as I've been down in Falmouth trying to get as much cider, pasties and rum down my 'clackers' as is humanly possible. Treat every day as if it is your last....one day you will be right!! |
Just remember the Vaseline. If the two leads separate bid-bulkhead your in for a world of pain!
Working predominantly with Ex-Navy and Merchant Navy individuals I'm sure there's plenty of vaseline to hand metaphorically speaking.
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Replaced mine recently (OEM) without problem. I tried the "taping ends together thing" but they came apart. However, bit of olive oil (well we are in Europe) and pushing and shoving and the end went through the bulkhead seal easily. Torchlight inside the dash and some groping around and the job was done
But shout it at them in German because life is also terrifying and confusing... |
