Home > Puma (Tdci) > Kenlowe Fan on Puma
Dieselhead
Kenlowe Fan on Puma
Hi,
Any of you fitted a Kenlowe fan on your Pumas???
I have a H/D which I took off my Discovery & not sure if its worth fitting or to sell it??
Any difference in power / MPG if I did?
Thanks Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #178780 24th Oct 2012 10:12pm
ellebarto
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I've fitted one more because I'd read of increased MPG and performance but I did it amongst a whole range of other mods so I couldn't really tell.
What I would say is I bought a cheap version first which let me down when laning one day and the engine overheated. I went ahead and got a Kenlowe but I seriously considered going back to the reliability of the viscous. Instead I always carry it because its simple to put back on.
I guess that might tell a story!
Post #179059 25th Oct 2012 11:13pm
pannawonica
Australia
I once fitted a Kenlowe to a Morris Marina B series engine. It replaced a fixed blade fan. The effect was dramatic, the engine wamed up quicker and had a much more effective heater. In addition it went faster and used less fuel at normal speeds. It did what was printed on the tin, however would I fit an electric fan? No. If you drive a Defender are you really concerned about fuel? Rolling with laughter
When it is over 50C, which it often is here I think it is better to use a few horses to drive a big fan. Being a simple system I would be reluctant to replace it with something more complex. Depends really on your useage. Thumbs Up
Post #179070 26th Oct 2012 5:45am
Tjhappel
United States 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I fitted an electric fan after having engine temp issues in cool weather with the viscous fan... It would never warm up in cold temps so I fitted a 2000 cfm electric which solved my winter issue but I also experienced issues in the really warm temps while towing. I subsequently found a 5300 cfm fan (hard to find) and built a better shroud for i, subsequently I have not had any issues since. I have an engine monitoring system and the highest I've seen temps go is 100c while climbing steep gradient, and 105c climbing same hill while towing (approx 2.5 tons).
I would recommend the electric fan only if you've had issues like I did in winter driving, I am a little concerned about the temps as I don't know what they should be with the viscous. It's WAY nicer for the extra power gain you normally wouldn't have when the viscous really spins in the heat, I haven't noticed much in the way of mpg difference, mainly just extra power in hot weather.
Post #179071 26th Oct 2012 5:52am
jst
in my experience fitting an electric fan does not give any justifiable improvement in fuel economy. You may get a quicker warm up time, depending on ambient.
if you have the space a correctly working viscous fan i think is perfect. something less to worry about, if the engine is running its running, no fuse to go or switch to fail (man or auto)
if you are limited for space or its a custom install (ie my rad is in the back) then electric fans work but i carry a spare sender (X-Eng type - so have never needed the spare Thumbs Up ), a spare fan (Spal) and you need a custom shroud. if you fit two fans in a shroud, have them both on at the same time and vary the two speeds with temp rather than just one on to avoid sucking air back through the 2nd fan if only one fan was running. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #179085 26th Oct 2012 7:16am
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
My SVX seems to be fittes with both! An electic and a viscous. Is that normal or am I missing something? '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #179100 26th Oct 2012 8:54am
jst
electric for the ac condenser. on the front behind the grill i take it? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #179101 26th Oct 2012 8:59am
Vera
That'll be it. Mr. Green
Bloody big for a condensor fan!! Smile '09 SVX #200
Post #179103 26th Oct 2012 9:01am
The electric one is for the air on and is standard for all Defenders that have it. Darren
Post #179104 26th Oct 2012 9:01am
