Home > For Sale & Wanted > Rear dislocation cones or similar for 110
Mountain_man
Wales
Before I buy a set, or worse, make a set, does anyone have anything sat around doing nothing they might want to move on?
Mark
Post #178845 25th Oct 2012 10:38am
Mountain_man
Wales
Well I bit the bullet and made a pair! Might even take some photos later when they are finished. Curse this Censored weather, can't do anything outside so back to the workshop it is! Razz
Post #178906 25th Oct 2012 3:29pm
jst
yes, i think i have.................................
Oh you dont need them
just change that ARB mount! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #179037 25th Oct 2012 10:21pm
TJ101
Or market it, as a 110 anti-handling kit ,, bound to sell on here Rolling with laughter Rolling with laughter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #179058 25th Oct 2012 11:13pm
Mountain_man
Wales
I have added a modification to the antiroll bar to prevent it from inverting. Need to give it a good testing but I reckon that it is now fixed!
Post #179066 25th Oct 2012 11:57pm
Can you explain a little more? What was the issue & how have you fixed it?
Post #179182 26th Oct 2012 3:24pm
Mountain_man
Wales
My issue is that I am running +2" shocks with standard springs. Not an issue in itself and easily fixed with a set of home made Dislocation cones. More of an issue is the fact\that I am running an anti roll bar on the rear (and front) which really help with the handling. However, despite fitting 2" spacer blocks to the ARB mount a situation arises (only on one side!) when on full droop the axle moves so far that the antiroll bar and the axle link align into a straight line. When the axle returns to the level, rather than the link falling back down it has been going upwards, ie. inverting. This places a huge strain on the ARB and the mountings and actually causes the truck to crab as the trailing arm bushes try to take up some of the forces. Not wanting to limit my articulation I wanted a simple solution to simply stop the ARB/link combo from being able to pass the point at which inversion could occur. So basically I made a shackle that fits below the joint and is held on by the bolt through the arb link and the end of the antiroll bar. Now when at full droop it is impossible for the ARB to become completely horizontal so when unloaded it HAS to go back down rather than up. I will be keeping an eye on it but a few tests have shown that it works fine.
Hopefully I have explained it OK. Will take a pic if you are interested.
Post #179203 26th Oct 2012 5:21pm
OK think I've understood - thanks for that Thumbs Up
Photos would be good if you have the time...
Post #179311 26th Oct 2012 9:38pm
