![]() | Home > Wheels & Tyres > Tyre Pressure monitoring system |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
Been up the caravan and motor home show this weekend, to get an awning, carpet cleaner, plates etc but also picked up a tpms to suit the caravan and 110 together.
It's here http://www.tyrepal.co.uk/products/tyre-safety-monitoring-system Looks like a good bit of kit, tried out a couple of the monitors and was surprised that a 62si caravan tyre heats up to 68psi when on the motorway Got a six monitor system for around £200 which seems pretty reasonable for peace of mind when towing (also its another gadget for the 110) monitors just screw onto the wheels you want to monitor so can be swapped from one vehicle to another, can monitor up to 22 tyres I think at £29 per extra monitor. Nothing shows on the screen until you get a puncture, slow puncture or drastic temperature change, but if you want you can check them by scrolling through the pressure and temp for each tyre that's monitored, so an in the background type monitor for safety. So all in all a good bit of kit for a reasonable amount compared to some others I've seen. Well worth a look if caravan/ trailer or even landrover tyres blowing out is a concern. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| Lewis07 Member Since: 06 Dec 2011 Location: Kent Posts: 67
I would question the accuracy of these things to be honest. Most I have experienced have caused nothing but trouble. |
I wondered that but reviews of this particular model are positive, and I have checked pressures that are displayed against actual with a digital gauge on several occasions and they seem to be consistent and accurate to date. (I'll keep an eye on that in view of your bad experiences Which ones have you had accuracy problems with? then others can consider your experiences with those models when thinking about adding a safety feature. A lot of cars these days appear to have various types of tpms installed as standard, are some of them known to be inaccurate as well? You haven't had a lot of luck really with the bonnet stain,leak,door locking and troublesome tpms, hope the dealer sorts it all out for you. I had the same locking issue once, I believe thats to do with a short on the door electrics, posts on here indicate that's the likely problem and its possible that some sleeving was missed off. Get the dealer to have a look see when he's doing all the other bits. I'm getting mine checked at first service next week. Mrs H is happy with the accuracy of her new carpet cleaner DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
The guy I bought it off mentioned some of those makes, I think he said they were in the valve stem (Does that sound likely?) and technology has moved on - we will see how it pans out.
One bonus is that the monitors are screwed on the top of the valve, so if one goes wrong it can easily be replaced (they have locking collars if you can be bothered to fit them, if the local lads like to unscrew stuff like they do) I'm more concerned with a slow or even rapid deflation than the actual pressure, as the alarm will (hopefully) allow me to pull over under some sort of control, rather than wait for a full on blow out, an excessive change in temperature will also trigger an alarm, as a precursor to possible blow out. I have always used the kick it method, but that's not so easy on a motorway : DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| speedymarktd6 Member Since: 02 May 2011 Location: Worcestershire Posts: 102
I think ken has got experience of tpms systems or uses them im sure he will be along to comment or you could ask him ?
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Having seen the carnage caused by a blowout whilst towing on more than one occasion I think £200 is a prudent investment. Having an occasional 'spurrious' warning due to possible stated unreliability is surely better than no warning at all? If you go through life with your head in the sand....all people will see is an ar5e!!
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I thought there was a special offer to forum members for TPMS ... I think there is a sponsor who specializes in them
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Yes here..http://www.landrovertrailair.co.uk/ 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
There is but I seem to remember it was quite a bit more money, fits into the wheel and probably a bit more sophisticated I'd guess.
Hopefully the sponsor will be along to confirm. That's what I thought K9F , worth it for a bit of peace of mind. I too have seen a couple of shredded tin tents, most likely down to tyres. My old man had a blow out when we were kids and I remember that being a bit scary - no crash though fortunately. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Talk to the guys at Comatra sponsors of this site good well built kit good mounting options as well
I use two one perm mounted in the puma ( in the process of swap to the new one) and a six wheel one for the tri ax trailer gives psi/bar and temp BMW /Mini at the low end use the abs sensors or the like and measures revolutions on each wheel not a valve sensor in sight, so when the weather changes you often get a failure warning because the tyre has expanded or contracted |
