![]() | Home > Maintenance & Modifications > vibration and rumbling |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Also check the handbrake drum and shoes - mine judders on the overrun at 80+ km/h when it's warm because the shoes vibrate against the distorted drum. Maybe a "shoe loose" (pardon the pun).
All the UJs still have nipples (mine's a Puma 110) but some are bloody awkward - I had to grind down my adapter. Think I even had to take the prop off to do one Actually not all of them have nipples as apparently LR sometimes forget to screw them in... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8484
prop shaft bolts? Cheers
| chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264
Thanks guys. will have a crawl under today and look. Definitely haven't greased them so I think that may be it.
| jlprojects Member Since: 10 Dec 2010 Location: now in Ireland Posts: 48
Mine was the same, after about 20 mins driving it started to vibrate badly. Turned out I need new UJ's. John
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
If it's as bad as you suggest, then greasing now is only likely to be a temporary solution. Chnaces are you'll need new UJ's. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Local independent garage think it's a bearing behind the handbrake drum in the transfer box! Yeah I realised non-greasing would have wrecked uj's. Bit of expense coming!
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Why do the damn things wait untill a Saturday afternoon before spitting a few needles out. I kept meaning to replace my spare one and of course it never happened so it'll just have to be nursed the next couple of days
