Home > Maintenance & Modifications > Emergency Lights Blinker
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Hi,
I promise... I have searched, and browsed the forum and although I know it has been discussed recently I couldn't find the thread.
The thing is, that the emergency lights switch in my Oct 2007 Puma, has stopped flashing when I switch on the emergency lights (blinker). I assume it is just the small bulb inside that died, can someone confirm this? and hopefully how to extract the bulb? (I know how to remove the switch from the dashboard)
Thanks guys, ciao Smile
Post #178633 24th Oct 2012 3:52pm
RRUK
Wouldn't it be easier to just replace it, assuming its not covered under warranty. You don't state if the hazard lights still work even though the switch illumination appears not to. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #178643 24th Oct 2012 4:43pm
CyberCharlie
Yes sorry, emergency lights work flawlessly.
I think is stupid to replace the whole switch if only a small light bulb can be replaced, no?
Post #178683 24th Oct 2012 6:44pm
The bulb is replaceable and the details are buried in THIS THREAD Darren
Post #178684 24th Oct 2012 6:54pm
agree it should be servicable, have you prized the front off the switch ?
to take the centre dash off, remove radio/cd unit, undo the torx screws and it should come off, there are threads on dash removal.
then you should be able to take the switch out of the dash.. let us know how you get on
Post #178685 24th Oct 2012 6:55pm
CyberCharlie
Hero!
Post #178695 24th Oct 2012 7:12pm
