Home > Technical > TC, ABS and Handbrake Lights on Defender Puma
TheWall
South Africa 2008 Defender 110 Puma 2.4 SW Alpine White
Hi,
Yesterday the TC, ABS and handbrake Lights started coming on after driving for a short while. Mostly on gravel roads...(Takes longer to come on when on Tar roads)
Sounds like 3 Amigos but that is not something that appear to happen to Defenders.
Anyone had a similar issue on Defenders?
Also got a short somewhere on a Right indicator that is blowing fuses but struggling to find it and not sure if it can be related...
First thing i think i should do is get my Landy on a computer.
What else can i do to get to the bottom of this?
Thanks http://banddc.blogspot.com/
Post #177922 22nd Oct 2012 10:58am
Naks
Re: TC, ABS and Handbrake Lights on Defender Puma
Check the level of brake fluid, the indicator for low level is the handbrake light.
As for the ABS/TC light, check and clean ABS sensors? --
Post #177931 22nd Oct 2012 11:55am
jst
check sensor leads to wheel stations Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177932 22nd Oct 2012 11:56am
TheWall
Is it hard to clean the abs sensors?
Will have a look when i get home...Guess i first need to find it. http://banddc.blogspot.com/
Post #177947 22nd Oct 2012 12:51pm
Glynparry25
Might be an idea to check your earths. I was having the same- could drive about town with no problems, and then hit a bump and the lights would come on. This also messed about with my lights.
Dealser had forgot to tighten the earth on the chassis.
Glyn Dog Sheep
Post #177988 22nd Oct 2012 3:26pm
TheWall
Glyn Dog Sheep
mmm, Ok, im dangerous with a tool in the hand Big Cry
Where will i look for the earth? http://banddc.blogspot.com/
Post #177989 22nd Oct 2012 3:28pm
Glynparry25
Rolling with laughter Rolling with laughter
Climb under the truck at the front passenger door. You will se the battery cable leaving the seat box. It then passes through what looks like p-clip but this is in fact an earth point so check the nut. It then goes on to the gearbox bell-housing where there is another nut- again check that one.
That was the problem with mine.
Glyn Dog Sheep
Post #177990 22nd Oct 2012 3:31pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
I have just had similar on my truck although it's a TD5 I believe a few of the wires are the same.
I checked the wire from the Battery - Chassis - Gearbox and the Chassis - Bulkhead with no luck and then found the fault, behind the header tank there is a grey multiplug with around 8 earth's going into it and a cable coming out and connecting to the bulkhead.
This plug supplies earth's for the ABS Unit, Dash, Heater, Hand Brake Sensor and some other key bits, my was not earthed correctly and causing all sorts of issues.
Jason.
Post #177998 22nd Oct 2012 4:13pm
K9F
TheWall,
I had almost the same symptoms as yourself nearly three years ago. It could be related to your blowing fuse as well as two of my looms (one being the TC/ABS) were chafing together! The following thread may be of interest perhaps? Good luck and let us know how you get on.....
Thumbs Up Thumbs Up
http://www.defender2.net/forum/topic2394.h...termittent If you go through life with your head in the sand....all people will see is an ar5e!!
Post #178028 22nd Oct 2012 5:38pm
TheWall
Ok, the Earth from the battery is properly grounded on 2 spots.
There is another cable that is loose. Looks like a earth cable.
Them bottom is tightened on the chassis but not sure there the top must go. Was tucked in behind the one air-intake.
Anyidea where this top bit is suppose to go?
Will read threw that other post in just a sec.
Thanks!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  http://banddc.blogspot.com/
Post #178039 22nd Oct 2012 5:56pm
Merlin
There is a Technical Service Bulletin on TOPIx that covers just what you have said. It’s LTB00078v2/2007. The thing to check is the earth connecter behind the brake servo (or that’s the way I read it). You might find the link by searching.
This information was given by Lorryman in an earlier post.
Merlin
Post #178105 22nd Oct 2012 9:24pm
TheWall
Ok, had it on the computer today.
Had a ground reference error on it. Checked the grounds and all seems fine. Lights came on again and the computer had a ground error again.
Also had a error basically saying i must clean the one sensor and that error is gone now after it was cleaned.
Going back on Saturday to try and sort the ground issue out.
The short on my indicators at least was sorted. Found the fault on the back indicator wire.
Thanks
Any other suggestions on where i can look for earth wires would be great. They say the image above is not a standard Landy Ground. They say it must be a after market accessory's cable.
Still trying to get info for the service Bulletin.
Regards http://banddc.blogspot.com/
Post #178903 25th Oct 2012 3:16pm
TheWall
Hi, been at my local Landy specialist and so far still no solution.
What we found out now is that it is only if the TC on the back wheels is triggered.
On the front wheels no issue.
Sensors been cleaned ad connectors between front and back has been checked.
Going back on Wednesday try clean something on the back wheels (Not sure what it is called.) and then hope that it fixes 3 lights issue
Also going to do a bearing service while it is there. Little play(3mm) on one of the back wheels.
Anyone had a issue like this before?
Post #179786 28th Oct 2012 5:20pm
TheWall
Hi,
Issue resolved...
Before i took at back to the dealers i took a hosepipe and sprayed of the back wheels. There was some mud left on there. That took case of the handbrake light.
Then after the workshop did my bearings and cleaned my (Think you call it a magnito) the other 2 lights went off.
Thanks for all the help http://banddc.blogspot.com/
Post #182183 5th Nov 2012 7:44am
TheWall
Hi, This issue is back...
Want to clean my sensors but dont want to break anything. How do i remove them...
The back sensors, can i just use pliers?
Post #213898 24th Feb 2013 7:20pm
