![]() | Home > eBay & Bargain Spots > FOXWING |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Think its a copy.
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
Not a copy - but a Fox Wing rather than a Foxwing.
Subtle difference in name, but it looks a lot different in the photo's 2002 Defender 110 DC |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Yeah, compared to the Foxwing, that's a crude Chinese-a-like. QRZ 2e0vpf
OK at the risk of being accused of spouting BS/trying to protect our commercial interest I have had a look at their other offerings.
If the fixing brackets are the same as another one of their awning brackets they are similar to steel joist straps, i.e bent galv mild steel strip with holes every 2". Genuine ones comes with moulded glass filled nylon brackets and a range of engineered brackets for different bars/racks Guy ropes plaited polypropylene (?) not kernmantel construction of genuine Oztent guy ropes. Am guessing not the Oztent P clip but plastic or metal slider. No weight given, genuine Foxwing is 18kg. Am guessing that the main rib poles are not of the same reinforced design of the genuine Foxwing. Uses standard hex bolts rather then the square headed ones supplied with genuine Foxwing. We will be extending our range of awnings and accessories in 2013. I will let you decide if we are adding this to our range or not. Brendan |
Or other words...
Can't believe that words censored
Actually I think the expression you are looking for is 'passing off.'
The law of passing off is designed to prevent misrepresentation in the course of trade to the public. Using the expression Fox Wing instead of Foxwing when aimed at that type of product could be construed as 'passing off' or misrepresentation as the public could think they are purchasing an Oztent Foxwing rather then a Chinese copy of an Oztent Foxwing which is patented. The patent might explain some of the differences between the genuine Foxwing and the chinese copy passing off as a 'fox wing.' Brendan |
