![]() | Home > Puma (Tdci) > Suspension lift. Light version |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
I have ome on the front about 40-50mm lift with no problems, and no changes to the transmission
| jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172
Thanks. Which ones exactly? Only the springs?
Hi Georges
I have the 751 fitted to mine but i do have a heavy winch and bumper, if you don`t have any extra weight on the front you could use the 761`s these will give you a 50mm lift. Take a look at the link below its very helpfull http://www.expeditionexchange.com/ome/indexsprings.php |
Hi
I was actually just looking at that. It looks like 761 in F and 755 in the back. Should I use trim packers to make it level? No change necessary to the shocks? |
I haven`t used the trim packers and it sits level and im using the std shocks
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
I got OME all around. 751 F and 755 R. But, pay attention. I got 1" in the back and not evern closer to 2" as OME advertise.
OME USA acknowledge their specs are outdated so they will pay for the missing inch in the back. I also doubt 761 will give you any lift. Why donīt you try with Gwyn Lewis spring spacer? They are very good and you can choose for 1 or 2". MK Puma 110" SW ............................................................. Earth first. Other planets later |
Thanks for that. I was actually looking at spacers with not much luck. This helps a lot.
This might be an easier and cheaper solution for what I want to do. One inch would be fine for me. |
I'm thinking either:
- one inch front only - or 2 inches front, one inch rear so that it sits level. |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
You don't mention if you've got a winch or anything fitted, but i tried some 110 HD front springs on my old 110 (factory HD;s, which are just 90 standard rears) and that lifted it a good inch, maybe slightly more.
however it made the steering very vague. Personally i prefer the "high" back end. |
no winch
I would leave the rear 1" higher than the front. Puma 110" SW
| Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166
I did a 2" OME lift to my 110 and it caused all sorts of drive shaft and vibration issues. I removed the springs to remedy this but due to the weight of the bar and winch the front went down considerably. I have found that the standard LR 130 springs lift the front to an almost verticle with the rear.
Allan |
| Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292
I fitted a set of Brit Part "Standard Height" HD springs to my last 90, along with their Super Gaz shocks. It made it sit 1" higher than before. Mind you this could have been purely because the old springs were past their best.
I know a lot of people knock the quality of Brit Part gear but I was more than happy with their performance and quality. The best part was no effect on steering or propshafts and I didn't have to inform my insurance company as it was not a suspension lift, merely replacement parts. MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
It looks like indeed the 130 sits more level than the 110:
| All times are GMT |
