![]() | Home > Puma (Tdci) > NEW GEARBOX |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
my click went with the new propshaft and second gear issue with a new selector Mike
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Sorry, but what do you call a "selector"? ![]() thanks M Puma 110" SW ............................................................. Earth first. Other planets later |
Hi MK, its a plastic thing under you're gear levers thats connected to the gearbox that helps you select 1/2/3/4/5/6 and reverse,
Ok. Thanks. I also have a rough 2nd gear. But only when shifting from 1st to 2nd not from 3rd to 2nd
![]() ............................................................. Earth first. Other planets later |
MK see your dealer now so if it gets any worse you have already told them thats how mine started, don't mean to worry you but get it logged
I´m going step by step. I´ll get a new TC as it clonks too much since 6000 miles.
![]() Stealer already changed the clutch assuming that is the cause of the dodgy 2nd.....I guess next is the GB time. Puma 110" SW ............................................................. Earth first. Other planets later |
Hi All, Had gearbox replaced today mmmm ? well its no better than the last one, or it needs to bed in im not to sure though, any one had a new gearbox and it's had to bed in or am i just hoping. Also had clutch replaced as Andrews mentioned there was a noise when turning it off thanks Andrews for that. But now when pushing the clutch in it seems weak very slack any ideas
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I think the newer clutches are much lighter. Is there any chance that it is just that? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
Problem from 1st to 2nd solved with a good gearbox additive......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
I googled for "a good gearbox additive......" and there were too many choices.
Yes that is what it is the clutch is just lighter and the gear box is a lot better now i'v done a few miles on it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Sounds like you're just suffering from 'progress' One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
![]() ![]() ![]() ![]() FINGEAR or Bardahl T&D Polarplus (I used this one) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
