Home > Maintenance & Modifications > Glue
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Glue
very frustrated. i have now stuck on the underbonnet NK kit twice.
1st attempt - degreased using detergent and a wipe with meths then stuck on using NK sticky surface. fell off
2nd attempt - degreased using brake cleaner and then use a spray can of glue to stick on. fell off again.
Now thinking about obscure swear words and using rivets Shocked
any ideas BM52
Post #176657 17th Oct 2012 9:19pm
cable ties ?
Post #176659 17th Oct 2012 9:22pm
Use the word Censored and arse !!! QRZ 2e0vpf
Post #176663 17th Oct 2012 9:23pm
Romadog
Had the same problem. Thought about using a piece of wire as in Range Rover Classic.
Post #176667 17th Oct 2012 9:28pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
What type of spray glue are you using I have found big differences between them.
Post #176669 17th Oct 2012 9:30pm
bm52
used Evo Stick spray can that says it can stick to metal, paint and take heat. BM52
Post #176683 17th Oct 2012 9:43pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Serves you right, Evostick sprayon!
Try something sillygoon based such as No Nails or one of the builders merchants ones, I tried a clear one from Wicks for various jobs, including ceramic to ceramic, metal to plaster etc. He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #176773 18th Oct 2012 10:24am
Tim_NZ
Australia
Nail gun?
Post #176998 19th Oct 2012 5:42am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Quote:
very frustrated. i have now stuck on the underbonnet NK kit twice. 1st attempt - degreased using detergent and a wipe with meths then stuck on using NK sticky surface. fell off 2nd attempt - degreased using brake cleaner and then use a spray can of glue to stick on. fell off again.
Know what you mean - mine is currently in the garage after falling off for the third or fourth time. Last time glue literally melted and the cover dropped on me whilst checking fluids in Morocco Sad Tony
Post #177880 22nd Oct 2012 7:57am
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
This stuff won't fail...
Post #177888 22nd Oct 2012 9:12am
