![]() | Home > Puma (Tdci) > Sweating Passenger floor... |
| derek Member Since: 13 Jan 2012 Location: Beckenham kent Posts: 94
Check posts for AC drain blocked as it soaks passenger footwell
Derek |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Better still..... http://www.defender2.net/forum/topic14249.html?highlight=drain If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
cheers couldn't remember the exact post
D |
Remembered the photos of the cut drain and the fact it wasn't too long ago....keyword was 'drain'.....
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
don't forget it's single skin and will get condensation under the carpet or mat. 2.4 90 XS
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314
Yes, but why isn't it happening on the drivers side though I'll get under there tonight and look for the drain plug anyway. Thanks all, Cheers, Superspoons |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Has anyone extended the pipe so that it can drain directly underneath the vehicle rather than run down the gearbox?
| Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283
i put a few sheets of newspaper under the mats, this soaks up any damp. and change it every month or so
lol...that takes me back a few years...don't suppose you use old underlay under your carpets for sound proofing as well
| All times are GMT |
