Home > Maintenance & Modifications > Snow cowl
Page 2 of 4 <1234>
Killer - So when will the D2 member's freebies be handed out then at Christmas? Whistle Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #176572 17th Oct 2012 6:04pm
familymad
Fitted Mud one today. Also fitted my mates one.
Great value at £35
Also took time to fit Brendan's rear door piston assembly. Kids won't be smashing the door closed now!! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #176608 17th Oct 2012 7:54pm
Killer90
Site Sponsor
25/12/2013 Rolling with laughter Rolling with laughter CSK Automotive
www.cskautomotive.co.uk
Post #176614 17th Oct 2012 8:03pm
Defender-Stu
Great value at £35
Easy to fit and how long did you have to wait?
Post #176642 17th Oct 2012 9:03pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Ordered an ex M.O.D one from Blanchards today ready for winter hoping it will help stop misting up inside. 2005 Td5 90 XS
Steve
Post #176646 17th Oct 2012 9:11pm
leeds
eutek wrote:
Put some araldite in the screws as well to keep someone from nicking it when I'm not around (based on prior experience of someone helping themselves to bolt-on accessories).
There is no easy simple ways of preventing theft of bolt on equipment or of complete vehicles. Whatever security methods you decide on please consider how your security means may impinge on you wanting to adjust/remove/repair your vehicle.
There are many security fixings around, some 'permanent or one way' such as clutch screws, sentinel etc or reuseable ones, pin hex, 2 pin, 4 pin, 6 lobe, pin torx etc. OK if Mr Scumbag turns up properly tooled up they can still nick your belongings but at least it will slow down/deter the opportunist thief.
Brendan
Post #176680 17th Oct 2012 9:38pm
familymad
Defender-Stu wrote:
Great value at £35
Took 5 mins to fit and arrived the day after I ordered - unbelievable service. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #176976 18th Oct 2012 10:36pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
[quote="familymad"]
Ditto mine arrived today 24 hrs after ordering from Mud.
Looks like it will be straight forward fit and will do the job before leaving on the trip 2007 TD5 90 Hard Top
Post #176978 18th Oct 2012 10:41pm
eutek wrote:
XS Pete wrote:
I fitted mine with with the Entreq cowl on top of the gasket on top of the original vent.
Me too, it was rather close to the wing without it.
What holds the gasket in place or stops it moving out of place ?
Post #177808 21st Oct 2012 9:27pm
double post...sorry
Post #177810 21st Oct 2012 9:30pm
Besides the obvious (snow) is there any other advantages to having one? ____\We|Will|Win/___
Post #177820 21st Oct 2012 9:53pm
Keeps general rubbish out which would otherwise eventually block the drain, which in turn causes it to leak inside when it rains. Darren
Post #177845 21st Oct 2012 10:22pm
I'm guessing that water ingress will also play havoc with rust in the heater internals over time, so fitting one early on and leaving it there all year will have a positive preventative effect (or may just be a case of man maths again!).
Post #177887 22nd Oct 2012 9:07am
RRUK
When you have removed the old vent on the top, get your arm inside the heater intake and check for leaves etc. Also, there is a small rubber vent hole in the bottom corner by the heater mating to allow for drainage which can easily block up with silt and mud deposits so get your little pinkie in there and make sure water can run out freely, otherwise your heater will expire from rust a lot sooner. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #177924 22nd Oct 2012 11:07am
WarPig
Got mine from P A Blanchards. Sprayed it Bonatti grey to match...
Post #177927 22nd Oct 2012 11:20am
Page 2 of 4 <1234>
