![]() | Home > Puma (Tdci) > Third World Travel |
The export 2.2 models sold in Africa don't have a DPF so I think the view is that they can't. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
I won't trust that so much. According to LR our Defenders should also not have a Catalytic converter and if you look on our vin numbers it also states "Non-Catalytic". But we ALL have Cats in South Africa. Might be the same with the DPF---not sure but IIRC our 2.2's do have the DPF......? |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
If someone could PM me the last 6 digits of a VIN from an African 2.2 I will have a little look at the build spec. VIN is visable on the plate facing out of the windscreen
I've got a 2.4 so no help but like I mentioned, from my VIN it states that my build spec is "Non-Catalytic" but I just removed mine last week........and so does all Pumas in SA have cats. |
Tuli Member Since: 17 Oct 2012 Location: Wiltshire Posts: 9 ![]() ![]() |
Thanks.
I have just got back from SA after living there for twenty odd years. I should have checked on their spec I guess. SA now has the 50ppm Diesel which would be fine but out of town it is rare. I am sure other developing countries will be much the same particularly in South America. BTW my old 300Tdi prefers the old 500ppm diesel. It sounds like I could take the DPF off when I leave on a trip out of Europe. Yes? Otherwise it is the 2.4. If I buy a ROW spec I can't bring it back to UK. I will try and find an SA 2.2 VIN 'Regard". Tx. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Tuli,
Depends of what countries are you expect to visit in SouthAmerica. At least Chile have a very good Diesel (Similar to European standards) Argentina also have a decent diesel as far as you use well known brands (Euro Diesel) Probably the same situation in Brazil, Uruguay, Venezuela, Colombia. Im not sure about the quality of the fuel in Peru, Bolivia ans Ecuador. So, I will not be so worry about bring a 2.2 here. probably you will have the same problems that you can expect i Europe. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
Remember DPF = for Euro 5 certification which only applied to Europe. If they don't need they won't fit them. |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
its true, there is a guy on here running a SA ecu map so he can run a de-DPF here in the uk.(kingsof the something is the user name...)
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Here he is. http://www.defender2.net/forum/member1503.html 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Thanks again. Great to hear from someone one in South America Eduardo and fantastic mouthwatering pics!
Tx 'spudfan' I will chase him and his expertise down. It looks like the 2.2 might be OK all round, even if I have to do a bit of surgery before shipping. However, teh 2.4 might do the job just as well. Any thoughts on the locking diff? Anyone? Tuli |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
IMHO stick with the 2.4 (it is better). It is unlikely low S diesel will be everywhere soon. Puma 110" SW
Cheers Tuli
Probably a 2.4 will be better, but I dont see huge problems using a 2.2. Some values Colombia have 50 ppm (Ecopetrol) Brazil 50 ppm from 2013 Venezuela 500 ppm Chile 15 ppm in the metropolitan area an 50 ppm in the countryside Argentina 10 ppm (Euro Diesel) to 150 ppm depends of the type Peru 50 ppm in Callao and Lima and 5000 ppm in the countryside Bolivia have 350 ppm Ecuador have now 500 ppm instead the 7000 ppm that have one year ago Paraguay 2500 ppm but you can get 50 ppm in the premium I hope that can help you Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Correct about the CATS, but in SA we definitely don't have the DPF's in our 2.2's. I have a written confirmation from LRSA confirming as much. The servicing schedule from LR is quite clear regarding diesel quality. 50ppm only allows you to extend up to 20k, 500ppm and you service at 10k, anything higher and heavy duty work, you service at 5k (all km's). I still think the 20k interval is madness for African conditions, hence I do it at 10k regardless if I use 50ppm or not. |
Yip, I agree on the 20k interval.....madness I also do only 10k, infact my last two services was only 7k appart but I am more than happy to spend those extra few bucks on my Defender. I also change ALL filters on every service! |
