![]() | Home > Technical > 110 front suspension height |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
110 HD fronts, AKA 90 standard rears do the job perfectly (as fitted by the factory)
With no winch etc fitted, you'll get about 1.5" of lift but with a winch the height is more or less standard. and they're cheap. |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Dave,
I have had the same problem with mine (TJM bumper, Spots and upgraded winch. My choice in the end has been togo for OME 751s. They should bring it back to standard height/ maybe a little bit higher. I am a firm believer in fitting upgraded equipment when it needs changing so will be fitting Koni shocks/ turrets and HD turret rings at the same time. Glyn |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455
Thanks for that,
Ideally I could do with an inch or so above standard as the winch sticks out the front and reduces the approach angle somewhat. Adding a slight lift would go someway to restoring this. Additionally, I dislike the "nose down, arse up" look however I appreciate I cant really lose this entirely. So suggestions of a plus 1 lift, with the weight of the winch, would be perfect. Thanks for the help so far, Dave |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
spring spacers? Cheers
| Bodsy Member Since: 20 May 2010 Location: Shropshire Posts: 61 |
I put 110 std height HD springs and shocks on the back, should I put HD on the front, has a winch bumper, but no winch yet will it make it too strong or should I stick with some new STD springs? Don't want to lift it really, although it will be higher than the worn out springs currently on the front I know
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
My 110DC sat nose down, i have recently put Famous Four +1 inch springs on the front and it now sits level, but has raised it over 2 inches measured at the front bumper
Depending on winch and bumper will indicate height.
I have a TJM bull bar: 25-30Kg Upgraded 8274 winch: 55Kg (inc failead and hook) Lightforce Blitz 240s: 2Kg So I have approx about 80Kg over a normal bumper. If you go for a smaller winch and regular winch bumper you will only have something like 40-45kg over normal weight so if going for OME 751s they will probably have about a 1-1.5" lift. Why do you need the clearance at the front? 110 as standard has an approach angle of 49 degrees, but a departure angle of 35 degrees. If you approach a slope at a 45 degree angle the front will clear, but then when your rear end gets there it will dig in and you will be going nowhere quick. If you drop the front by 1 inch with a winch you will probably still have a 35+ degree approach angle. Glyn |
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
I have a heavier bumper, a warn 9500HSi and will have a bull bar with lights...As someone mentioned above, I fitted HD springs to the front of my DC...And they're fine! It's levelled and performs well... Regards
Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
