Home > Technical > HELP! Front hub removal problems
coln18
looking for some advice, i was trying to remove my front hubs on my 2003 td5 110 to replace the discs and pads, i have removed the dust cover, circ clips and washers and the five hub bolts but the hub driving members are totally stuck and no matter what ive tried i cant budge them, they seem seized onto the halfshaft. i have tried heating it up with my torch, sprayed 800 gallons of wd40 at the damn things and even bought a spring puller but all to no avail, has anyone had this problem and if so how did you get round it?
was thinking of tapping the 5 bolt holes and then adding bolts to slowly force it off or last resort cutting it off, but worried about damaging the half shaft assembly which aint so cheap to replace, any help will be appreciated from you clever guys.....
Col
Post #176291 16th Oct 2012 6:39pm
rustandoil
Have you removed the big 38mm? nut
Post #176296 16th Oct 2012 6:54pm
jst
there is no nut holding the drive member on, just the circlip
can you not rotate the DM and then get in behind on the flat edge/lip that is exposed when it is out of sequence?
i large pry bar and lump hammer will do it eventually. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176336 16th Oct 2012 8:27pm
Toplink
The FBN is behind the driving member.
Use an angle grinder with a very thin disc and slowly cut through the driving member from front to back ,carefully to avoide damaging the hub or half shaft.it is impossible to avoide a few nicks,these will not affect the components.When you have cut a number of slices beat the slots now prwesent in the drivivng member using a hammer and cold chisel.
It works.
I remove my dust/hub caps every service and grease the splines and my sure they are free.
FBN = F Censored Big Nut. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #176371 16th Oct 2012 9:48pm
Try using a hammer and drift to rotate the drive member until you can use a puller to pull the DM off the halfshaft.
Post #176400 16th Oct 2012 11:04pm
rustandoil
Absolutly correct, note to self: must read properly before posting Whistle
Post #176420 17th Oct 2012 5:58am
jst
put it in gear and attempt to drive it with foot break on no diff lock.
or
use extended bolts and a pry bar to lever it around Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #176424 17th Oct 2012 6:43am
