Home > For Sale & Wanted > FS - Puma radios, center tray, basic steel wheels
I am having a bit of a clear out and have the following items for sale:-
1) Genuine Puma radio, basic spec (ie the one without the AUX IN). With code plus the little metal thingies that fit the sides of the slot in the dash. £45
2) Genuine Puma radio, XS spec (ie the one with the AUX IN). With code plus the little metal thingies that fit the sides of the slot in the dash. £70
3) Genuine Puma centre tray (the thing you have if you don't have a cubby box). Used but good condition. £35
4) Four Defender 90 genuine basic white steel wheels. These were new take-offs with delivery mileage only and are in good condition. They are the welded type (not the rivetted type as used on Series vehicles) and *I think* are 5J16 size. Thay are at present in my storage unit so I can't readily check. £50 for the four.
All the above will be advertised (at slightly higher prices) elsewhere if there's no interest here.
Finally, nothing whatsoever to do with LRs of any kind, but they've got to go and there might be someone on here intersted:-
5) Two Perkins P6 diesel engines. One complete good runner ex-Bedford/AWD RAF snowblower c/w clutch and gearbox, the other industrial with drive plate and coupling, complete except for crankshaft and pistons, plus various other P6 and S6M spares. £1000 the lot.
*EDIT - spelling. Why do typos only appear after you click SUBMIT?
Post #176211 16th Oct 2012 11:39am
item 2 pls
Post #176215 16th Oct 2012 11:50am
familymad
Where are you. Wheels for me...... 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #176216 16th Oct 2012 11:51am
Item 2 reserved for Ken, Item 4 for Familymad.
PMs sent to both.
I should have said in the post that I am in Poole, Dorset, but the wheels (and P6 diesels) are in Shepton Mallet, Somerset at present.
Post #176219 16th Oct 2012 12:06pm
