![]() | Home > Technical > Wiring Header Joint Locations |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570 ![]() ![]() ![]() |
I would ask the question over on lr4x4 forum lot more technical advice over there.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
The rave electrical section shows pictures of the various joints.
If you know the joint number, then you can find it in a list on there, and it gives a picture and location |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
K108 and K109 are the ones i'm looking for.
Thanks |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
K108 is earth header C0550 on the bulkhead in the engine compartment - ![]() Every splice connector circuit header in the loom is designated K109, so you'll need to be a bit more specific about which connector/circuit you're looking for. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
