Home > Maintenance & Modifications > Flip down side steps?
Has anyone got (or can they take some...) pictures of the underside of a LR showing where the side steps bolt onto the sill?
I think they go onto a couple of the bolts that hold the floor plate down, but mine don't line up that well.
cheers Thumbs Up
Post #175177 12th Oct 2012 7:26pm
spudfan
Ireland
If you are worried about a slight lean by one side or the other or both don't be, standard fit arrangement.Hope to get them photographed and uploaded this weekend, unless someone beats me to it. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #175178 12th Oct 2012 7:32pm
spudfan
Ireland
Have not forgotten, trying to locate the lead to connect the camera to the laptop - (again) 1982 88" 2.25 diesel
Post #176899 18th Oct 2012 8:08pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Hi the genuine land rover side steps don't bolt through the top floor plate bolts but bolt through the back of the sill channel.
Post #176969 18th Oct 2012 10:25pm
HI all
Yeah, I had a browse through RAVE and found the install instructions, and see as DB950 says, they bolt through the back of the channel.
All I really need now is the distance from a reference point to the bolt holes (just so I can fit them in the factory position)
cheers Bow down
Post #177011 19th Oct 2012 7:58am
db950
Can take the measurements off mine when I get in later if that helps.
Post #177012 19th Oct 2012 8:07am
Welshsurferdude
Wales
they do indeed bolt to the back channel of the sill, just fit em roughly in the middle of the door and see which holes they line up to.
i fitted mine last week and only took me 5 mins per step without looking it up Smile 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #177020 19th Oct 2012 8:38am
Cool. I did wonder if the sills were already pre-drilled. must crawl underneath and have a gander.
Post #177046 19th Oct 2012 10:22am
Welshsurferdude
Wales
Get under there and wiggle it about til the holes line up Smile steps might need a lil persuasion but that's Lr for you, holes are pre drilled 2011 Santorini Black USW XS.
Post #177050 19th Oct 2012 10:41am
farmer giles
yep, holes definately pre drilled; i retro fitted 4 on my 110.
did need to use a rivneut tool to install nuts in the chassis though.
Post #177086 19th Oct 2012 12:57pm
Thanks all.
The steps are currently drying in the garage (fresh coat of black paint), will get them on later.
Post #177121 19th Oct 2012 3:02pm
walfy
I have a big rivnut tool if you need to borrow Jamie. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #177131 19th Oct 2012 3:30pm
Got one here cheers Mark Thumbs Up
Post #177156 19th Oct 2012 4:28pm
