![]() | Home > Puma (Tdci) > LH Drivers be aware! |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Not sure if this has been discussed but I was reading LROI and came across this!
If you hear a banging noise when at full articulation in extreme off road conditions then it is the front propshaft hitting the sump on the engine! Their is a modified sump out which your dealer will fit if you complain of this. EDIT-This only seems to affects Left Hand Drive vehicles! Ben Rebuilt 1996 black/white Defender 90 300 TDi |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Yep,, see http://www.defender2.net/forum/topic222.html?highlight=
The modded sumps are on back ordered at present, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Oops, fought that was something else!
![]() Rebuilt 1996 black/white Defender 90 300 TDi |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8371 ![]() ![]() ![]() |
i believe its LHD and RHD vehicles, as Tim says how can it be any different, sump and props are in the same place. i think its more a case that the terrain they are used in o/s is different to the uk ie rockier therefore there were only LHD failures. Italy had the first failure i believe. Cheers
