![]() | Home > Technical > Webasto thermo top C telestart |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
OK,
Violet = ventilation When pressing a certain button combination on the remote you can switch from heating(winter) to ventilation (summer). So besides plugging in you also have to enable (if you want this) the ventilation mode from the remote and therefore also plug into the violet wire. (the first part of your explanation= connecting W-bus and power, the second = connecting to the "ventilation only" wire. The difference with starting up the heater in normal mode in summer is it will also ventilate and cycle without heating but the heater will go through its start-up and shut-down sequences. If you enable ventilation mode the heating parts of the unit are not fired up and left alone, you just control the ventilators. ![]() ps: i guess the whole violet wire is only a simple make earth connection for the startup signals to the heater parts. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
thank you, well i dont want the ventilation option so i will just plug it all straight in without extending the violet in to the loom. thank you.
wrt to the airtop post and wiring you can see where this is going now! intent is Airtop on Rheostat Thermo Top on Oval timer both independant controlled resp. by above. BUT remote both of them to come on simultaneously. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
What you are proposing is absolutely no problem
wire your pin3 of the T70 (the on/off 12v signal) to pin 7 on the airtop and to the right pin (which i do not remember) on the thermo top. You will need to put a diode in both wires or your timer/rheostat will also switch on the other device if you switch on not using the remote. I do not have the diagrams here at hand of the thermo top layout, but i am sure Dargel has them linked in one of his webasto threads. ![]() |
Excellent, thank you and good reminder about the diode. Cheers
