![]() | Home > Maintenance & Modifications > TDCI 2.4 Puma Oil Service Video |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
I made a short video while changing all the Oil on my TDCI and uploaded it to Youtube to help anyone that may be thinking about doing the same job.
![]() http://youtu.be/sNFfdnfycYg ![]() Click image to enlarge Mermoto |
Brilliant!
![]() Fancy doing a video for the whole vehicle? ![]() But shout it at them in German because life is also terrifying and confusing... |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Excellent video but the picture above clearly gets you from a better angle ![]() |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Excellent! Where did you get those ramps? They are the business. Was that a Rotty I saw? Love them, any pictures?
Merlin |
Thanks for sharing
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Thanks Mermoto I really enjoyed that. Definately better than Holby which is whats on telly at the moment !
I've done all those jobs (different technique for the G/box oil but who cares as long as you can get it in - its a pig) except the fuel filter. I'm a bit scared of that one as I don't want any airlocks but seeing your vid I might have a go. Cheers |
Cheers guys!
The ramps are brilliant, they are called display ramps like you see outside car dealers showrooms. They are pretty heavy duty too. A bit scary the first time driving up them though, but at two feet high they make getting under the Defender a lot easier. Looking forward to washing and re waxing underneath next spring using them. Should be much more fun. There are two sets of Display Ramps on Fleabay at the moment! Mermoto |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
great video, thanks. did you just fill up the new fuel filter and fit or did you bleed any air out after fitting? BM52
Hi bm52, After lots of reading I filled the new filter to the very top and stood it upright in the box you can see in the video. Undid the old filter and carefully removed it and put the new filter in place without spilling any fuel. The amount of fuel that leaked on removing the old one was only a few drops. No bleeding was required. As I understand it the fuel flow is under such pressure as it passes along the injection rail, any bubbles may be sucked past the injectors and fed back to the tank. I suppose the odd air bubble that goes through the injectors is not going to have any effect on a running 2.4 litre engine. It didn't miss a beat. Mermoto |
thanks for the clarification. mine is 3 years old in Jan so next year i will be servicing it myself and these 'tips' are very helpful
![]() so far all i have done is change the oil at 6 months. so far it has been very reliable....until the reversing light failed a few days ago. cheers, bm52 BM52 |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Ditto !! Brilliant video, definitely going to save a few pennies by doing it myself.. Have a 3 bay HGV pit at work, so access should be good! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
