![]() | Home > Off Topic > Petrol in a Diesel car Question |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
First thing is first..... assume the possition in fron of him:
![]() ![]() ![]() ![]() ![]() ![]() ![]() How much has he put in? The tank will need draining and the system flushed through there is the possibility of damaged parts too, but that will be dependant on how much petrol to diesel there is in the tank. Call the AA/ RAC, they will tow him to the nearest place that can do the work. It will cost about £200-500 to have the tank drained and the system flushed. Glyn ![]() ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Drain the entire fuel system I'd have thought or at a minimum back to the fuel filter at the very least. Other that that very expensive! _\Hennessey|Venom| F5/___
___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
We have all been ribbing him and laughing at him already
![]() ![]() the AA have just turned up so we are laughing out the window at him and so is the AA man ![]() |
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 ![]() |
I did it once in France, in my defence I was knackered and probably shouldn't have been anywhere near machinery!
Anyway, petrol into a diesel is OK (even if you've been driving it) once the system has been flushed and new filters in. Diesel in a petrol is not so fine, even less so if you have driven it. Not sure about the AA but there are a few specialist firms out there that will come and flush your system on the spot. Nick 2.2 110 Tipper |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Ehhh, not to step on anyone's knowledge, but petrol would act as a solvent in a diesel car, and is extremely bad.
Diesel in a petrol (even if you managed to egt the wider nozzle into the tank) is still bad, but as you are essentially adding unwanted lubricants, you will get smoky exhaust, and bunged up filters. Either way, need draining & flushing. 2001 TD5 110 DCPU in Bonatti Grey |
Hopefully it has not seized the diesel pump which with putting petrol in to a diesel car can be bloody costly if not caught early enough!
A few years ago, my wife filled her company diesel Renault Laguna with petrol and it got about 12 miles before lurching to a stop. A couple of hundred pounds later and the tank had been sucked dry, re-filled with derv and off she went. No ill effects to the car, but endless embarrassment for my wife
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 533 ![]() |
petrol in a diesel will goose the fuel pump as a minimum, these are high pressure and rely on diesel as lubrication. Diesel in a petrol is not too bad, and is usually ok with tank drain, pipe blow through and filter changes and get away without damage.
How much was put in? _\Hennessey|Venom| F5/___
£20 went in for petrol and his insurance company xs is £175 and have already confirmed this is covered and the car has been picked up 3 hours ago
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 ![]() ![]() ![]() |
Diesel in a Petrol wrecks the oxygen sensors in the exhaust.
A friend filled his Honda V-Tec years ago from the unleaded pump at his regular garage, he managed to drive 5 miles to the dealer but needed a new cat and sensors plus the drain. When he challenged the garage they informed him it MUST have been his mistake, half an hour later he got an appologetic phonecall, the garage owner had just filled his Jag from the same pump and couln't get off the fourcourt. The delivery driver put fuel in the wrong tanks ![]() Had a couple of folks at my last job fill up the pool car with petrol, indeed I was the passenger on one of the occasions, I was half asleep as it was an early start so didnt take note, when the car started juddering and ![]() ![]() |
Fair bit then. The less the better. I've always been used to buying nothing but diesel and always check but for those of you that have that have vehicles that are petrol and diesel I can see how it could easily be done! _\Hennessey|Venom| F5/___
Luckily you can make that mistake only "unidirectional", meaning petrol into diesel.... A diesel filling spout will not fit into a petrol filling opening as they made it on purpose much thicker. So you will get stuck before the diesel spout could open the petrol tank valve which makes it quite unlikely not to notice something is wrong. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
There will be a variety of stories because a lot will depend on filling habits.
If you fill up once you hit 3/4 tank and you accidentally add 15 litres of petrol to 60 litres of Diesel you shouldn't have much problems because it is a 2:1 ratio But if you are someone who likes to empty the tank before filling then put £100 petrol in you are going to break something at it is straight petrol going through the system. I have known many people who have made this mistake (my dad twice when he had a bike and my mum had a diesel). Both occasions it cost £200 for the work, £60 lost in fuel (when they drain the tank it goes straight into waste tanks, and then £60 for another full tank of fuel. That is only because my mum keeps a minimum of half a tank (has to do a 40 mile commute across a remote hill route). Glyn ![]() ![]() |
