Home > Puma (Tdci) > Stock power limit
ZeDefender
Stock power limit
Quick question:
If the peak power is 122PS for all Pumas, is it limited passively or actively?
In other words, is the stock engine simply physically incapable of producing more peak power (in which case Pumas should vary quite a lot), or does the ECU actively choke it?
If power/torque are actively and precisely choked, presumably just fitting a bigger intercooler, turbo, EGR blank etc. with no remap won't have much noticeable effect...
Good morning to all
Matt Tell someone you love them today because life is short.
Post #173300 5th Oct 2012 8:16am
T1G UP
the ecu dictates the fuel...so the fuel dictates the power/ torque...upto a point.
plus there are quite a few obstacles that can easily be overcome to aid flow and as a result increase drivability / power / torque.
de cat, inlet tract, intercooler to name a few
Post #173303 5th Oct 2012 8:18am
ZeDefender
So presumably, since I can read power/torque with the Scangauge, so can the ECU... and kill the fuel when it gets worried.
I wonder if bigger intercoolers etc. just help by "filling in" flatspots etc.
My theory is that the peak power/torque is ECU limited but hardware tuning gets you to the top faster. Personal experiences would help me get my head around it Confused Tell someone you love them today because life is short.
Post #173307 5th Oct 2012 8:28am
K9F
Not sure if I've missed your point here but BHP and torque are increased with remaps above standard figures so that makes the engines capable of more?????
See below for examples:
http://www.james-french.co.uk/aftersales/l...r-upgrades If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173308 5th Oct 2012 8:33am
ZeDefender
Cheers.
I know that power/torque is LR-software limited and remaps can "allow" engine parameters like turbo pressure, fuel rail pressure to increase above LR-desired values, even with no hardware changes.
I'm wondering about the opposite: what happens if you beef up the hardware but keep the software the same?
How/does it change performance? Tell someone you love them today because life is short.
Post #173311 5th Oct 2012 8:41am
K9F
I can only speak from personal experience and I do know that for example if you fit a decat pipe either on a remapped or stock vehicle that there is a noticable difference straight away on acceleration as it allows the turbo to 'spool up' quicker, so the answer would have to be yes....hardware can increase performance within standard software parameters. The decat is I would say the most 'cost effective' modification for increased performance in my opinion.
With regards to larger intercoolers, silicone hoses etc. I would be interested in feedback too on how different the vehicle is and if there are any significant gains to be had! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173314 5th Oct 2012 8:48am
ZeDefender
Just heard from another member in a hot climate with no software mods.
Bigger intercooler makes massive difference to him (as expected from the hot weather point of view) but it also sounds as if it has significant effects on cooler days as well...
It seems as though fuel consumption improves, as though as better response and pulling under load. No absolute figures but it does sound as though even within LR's "cage" there is a lot of room for improvement.
So I'm just "Scangauging" different EGR blanking setups and then, eventually, an Allisport - still under warranty so have to be careful Rolling Eyes Tell someone you love them today because life is short.
Post #173321 5th Oct 2012 9:25am
K9F
I 'threw caution to the wind' and carried out all my 'performance enhancing' mods whilst still under warranty after due consideration and a hell of a lot of research. EGR valve blanking, stainless exhaust getting rid of backbox, Autologic remap, decat etc. etc. No regrets there whatsoever. I did however retain all my original parts for the warranty period just for peace of mind and my companion 'Justin.'
'Just in' case. Laughing
I too would like an intercooler, pipes and possibly a hybrid turbo but have to refrain as I don't really do the current mileage to justify and with recent spending SWMBO must also be appeased somewhat.....
Embarassed Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173328 5th Oct 2012 9:45am
JWL
A bit off topic but I wasn't in a position at the time to experience anything. When the Td5 went from non cat to having a cat fitted from 2002 onwards to meet eu regs, was there a noticable change in performance? I only ask because de-catting mine made quite a difference.
Just curious after all this talk with the apparent differences with the latest tdci's.
Post #173329 5th Oct 2012 9:50am
Naks
Beyond the usual h/ware mods like de-cat, intercooler upgrade, etc., you have the s/ware remap, which also gives a power/torque boost
If you want to go beyond that, then you have to do some serious mods, like bigger turbo, new pistons, fuel pump, etc. But the durability is then on an inverse path to the power generated. --
Post #173331 5th Oct 2012 9:56am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
you lot not read Porny's thread on here ? Whistle Putting Dreams on Drives at JLR Solihull..
Post #173347 5th Oct 2012 12:22pm
ZeDefender
Link please? Bow down
Couldn't find much concrete info on performance improvements/limits with better hardware but standard map Embarassed Tell someone you love them today because life is short.
Post #173354 5th Oct 2012 12:44pm
adafish
try this... Defender 2.2 Tuning/Remap from IRB developments! Putting Dreams on Drives at JLR Solihull..
Post #173355 5th Oct 2012 12:53pm
K9F
Laughing But the poster's got a 2.4 why would he read it.....
Also this thread isn't about mapping!
ZeDefender wrote:
I'm wondering about the opposite: what happens if you beef up the hardware but keep the software the same? How/does it change performance?
Without wishing to court controversy. There are loads of threads about remaps all professing by avid individuals to be the best (compared to what I don't know) but they are very rarely (if at all) backed up by facts and figures from a dyno...each vehicle is different I know but a before/after comparison against a standard one shouldn't be too difficult to produce.
Whistle
Back on topic....Again I suppose each vehicle is different and operate in differing climes but a clear concise explanation of what benefits for example an intercooler would afford the purchaser in layman's terms would for me be most welcome. Loads of people sell them without much explanation. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #173356 5th Oct 2012 12:58pm
ZeDefender
Perhaps I should explain further: I have a terrific remap from Alive but I still get intermittent shaking of the vehicle. Gary has gone to a lot of trouble and done a great job but obviously my 110 doesn't want to play nice Rolling Eyes
Therefore, I want to find out what we can do to improve performance of a 2.4 without remapping and what that improvement will be, from personal experience... "in layman's terms", as the venerable gentleman put it Thumbs Up Tell someone you love them today because life is short.
Post #173364 5th Oct 2012 1:09pm
