Home > Maintenance & Modifications > Chip tuning
MK
Chip tuning
Hi guys:
Has any of you fitted this:
http://www.racechip.de/racechip-chiptuning...972-r.html
Looks like an afordable bit
thanks
M Puma 110" SW
Post #17295 27th Oct 2009 2:08pm
Grockle
Re: Chip tuning
MK wrote:
Hi guys:
thanks
M
Seems very cheap to me,when you compare what BAS ,Twisted etc.,charge 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #17297 27th Oct 2009 2:27pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Crikey that is cheap. Shocked
Post #17299 27th Oct 2009 2:59pm
totoD110
Im interested on this. anyone using it already? Smile
Post #17301 27th Oct 2009 3:14pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
A word of caution on cheap plug in tuning "chips", although I have never used this type of system, this is what Gary at Alive Tuning (formerly TD5 Alive) says about them:
Quote:
External plug in tuning devices fool the engine management into thinking it's injecting a pre-determined amount of fuel, when really the tuning box is increasing the injector opening time, just to put more fuel in, regardless of what is happening with the rest of the engine.
The most common plug in tuning devices simply plug into your engine's fuel rail pressure sensor, and add a greater resistance to the supply voltage. This fools the ecu into thinking there is low fuel pressure, so the ecu then increases fuel pressure to the rail to compensate.
This overpressurising of the fuel rail will allow more fuel to enter the engine when the injector opens, hence making more power. A crude method of tuning to say the least, but one that is so common!
I have no connection with Alive Tuning but I know of Gary from the Disco Owners Club forum where he always came across as a very straight forward guy and extremely knowledgeable. Those people I know who have gone for his tunes have been very pleased with the results. MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17353 27th Oct 2009 10:51pm
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Re: Chip tuning
MK wrote:
Hi guys:
thanks
M
I'm using racechip since 3 weeks, and it works very good: more torque and acceleration, too much in 1st and 2d gear, but very funny in 3d, 4th, 5th and 6th gear. But when You drive with throttle at minimum and icrease it just a little bit You smoke. This problem is caused by EGR valve that remains open in this condition.
Post #18307 13th Nov 2009 4:22pm
Martin
Site Admin
Those devices do not and cannot work anywhere near as well as a proper remap.
All they do is "fool" the ECU to believing that the engine is running differently to what it's actually doing, and fooling the engine into things the ECU isn't telling it to.
The simplest of these boxes simply increase the fuel rail pressure, so for each injection there is more fuel going in. But the ECU doesn't know that, and doesn't adapt anything else it does.
A proper map, although more expensive, does a heck of a lot more - it changes more than just fuelling pressure - timing and duration can be changed, as well as lots more maps to do with airflow, still respecting in-gear torque limits, etc etc etc.
Post #18312 13th Nov 2009 5:46pm
jst
it will do the job to some extent but the job can be done better, my money is going to Pete for a full on system rather than a one shot and wonder.... Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18366 14th Nov 2009 9:03pm
chay
Wales
I tried and drove several varients before I purchased an upgrade and counting and weighing up all the possibilities, there really is only one sensible option for the Puma.
A BAS upgrade. Optionally reversable as many times as you like, tuned for your requirements. It works and is reliable.
Job done.
Post #18406 15th Nov 2009 11:59pm
MK
What would happen if the rig fails and you need to call LR assistance? Puma 110" SW
Post #18409 16th Nov 2009 12:39am
chay
Wales
I keep the re-tuning box (it's only small) in the pocket behind the seat, and can re-tune/de-tune on the spot. If you read some of the threads on the forum about the BAS tune I think you'll find most of the questions answered.
Very Happy
Post #18427 16th Nov 2009 9:20pm
Mad Cow
No that wouldn't work......
I haven't got a pocket behind my seat Laughing MAD COW
Project90
Post #18440 16th Nov 2009 11:00pm
jamesbond007
Portugal 2009 Defender 110 Puma 2.4 XS DCPU Rimini Red
Same here, well behind the rear seats actually. Boldly going nowhere
Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular.
Post #18458 17th Nov 2009 8:50am
dgardel
Italy
Re: Chip tuning
vinsell wrote:
MK wrote:
Hi guys:
thanks
M
Ciao Vinicio,
same problem if you REMAP (not add-on) and give more fuel around 1800-2500 rpm....
black smoke (pay attention because this smoke will deposit inside you inlet manifold, I must clean a lot of it)
My solution was: TAKE OFF EGR connector (ok I'm running with MIL lamp on but my engine and are happy now)
Try it and report to me your considerations.
After that I'm waiting Pete (Bell Auto's) REMAP box.......
SO I'll can report the results
Daniele
p.s. we have the same side step....
for me the best but you need to spray it inside the tubes with waxoyl otherwise the rust came on Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18465 17th Nov 2009 10:13am
MK
I`ve been using the racechip for a couple of days. It certainly gives more power and torque at about the rpm range as std. For a spectator knowing how these rigs are, must be like "what the hell". It is just not normal how fast you can go. Puma 110" SW
Post #19812 11th Dec 2009 1:21am
