Home > For Sale & Wanted > WTD TD5 15p engine (Now got one thanks)
Page 2 of 2 <12
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Well I believe I am now past the point of no return.
Post #171827 29th Sep 2012 7:35pm
Blimey Shocked Good luck! Darren
Post #171841 29th Sep 2012 8:04pm
rustandoil
You have a servo on your clutch?
Liking the big hammer on the wing Rolling with laughter
Post #171848 29th Sep 2012 8:15pm
jasong4110
Cheers, it was actually not that complicated, not sure what all the fuss is over TD5's being complicated.
Yes it's a Red Booster Clutch servo, allows Mrs S to drive the defender, No1 Land Rover tool was required on several occasions today!!
Post #171851 29th Sep 2012 8:19pm
looking good / empty Jason Thumbs Up
hope the next photo is a bit fuller Shocked
Post #171857 29th Sep 2012 8:50pm
jasong4110
The next photo will probably just be a bit cleaner, or and with some additional insulation.
Jason.
Post #171860 29th Sep 2012 8:53pm
jasong4110
Ian very kindly brought the replacement engine down to my house this evening, so I just have to stick it in now..
Jason.
Post #173474 5th Oct 2012 10:20pm
T1G UP
cool.
get stuck in.
Post #173476 5th Oct 2012 10:22pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
One of the best modern diesel engines you can work on at home with minimal tools in my opinion.
Steve
Post #173487 5th Oct 2012 10:54pm
T1G UP
Steve
until it goes wrong then it's scrap and you have to buy another.....i
Post #173515 6th Oct 2012 8:09am
JSG
Good luck Jason - if you need another pair of hands just shout Thumbs Up John
2011 Tdci 110 CSW XS
Post #173533 6th Oct 2012 9:39am
jasong4110
Well with a help from a few friends (7) the replacement engine was fitted yesterday, Clearly it didn't need this many but with the promise of a free breakfast and lunch there were plenty of willing helpers. This group fix it type thing is actually great fun, lots of banter and shared knowledge and learning, jobs just get done quickly and the time goes quickly.
With a bit of pushing and shoving it slotted home nicely and bolted up well, by lunch time we had the engine back in on the mounts and the loom back in. I think threading the loom is one of the more complicated jobs, fairly easy if you know what you are doing but potential to thread it the wrong way which we did!! Fortunately one of the group had a TD5 so we were able to double check things.
Curry and cake were followed by the installation of the rad pack connection of the hoses, a check to see we hadn't missed anything, followed by the addition of 65% mix antifreeze and the oil. Then a check for leaks revealed none so it was time to reconnect the battery and cross our fingers.
Purge cycle started, and a further check for diesel leaks whilst the system was under pressure nothing found so only one thing left to do (well a few things left but one before starting) I had decided not to change the injector codes before we had tested the engine ran as I knew they would run with the wrong codes and I didn't want to add any other fault possibilities before we knew it ran.
So it was time to turn the key and crank her over, well almost it was when Steve had managed figure out his camera!! Ignition on and key turned, the engine hummed into life on the first turn. Very Happy
We ran it for a short time and then turned her off in order to check for leaks and set the injector codes, injector codes changed and it was time to start her up again. It sounded nice and ran well, checked that she engaged gear and moved all good, Neil then checked for faults and noticed that the voltage was only 12.3v.
Voltage checked at the alternator and nothing, clearly we should have been getting at least 12.3v. We checked for continuity but nothing. On close inspection the multiplug on the back of the alternator was not connected, this was clearly and issue but we still should have been seeing voltage. When I had started to look into moving the ECU that the charging wire came from the loom into the back of the mega fuse pack before going to the batteries.
We tested the wire and the fuses but nothing so I checked the battery side and got voltage, clearly the wire had developed a fault during the replacement process. I quickly made another wire up and we fitted it externally to test cranking the engine the battery light went out and we got 14.3v.
Time was pressing on so that's where we left it, I need to make up and thread the replacement wire refit the turbo shield acoustic cover front grill and bumper and then we are done.
Then time to give it a good shakedown test before taking it off the road agian to finish prep for Norway.
Jason.
Post #175818 14th Oct 2012 11:35pm
Page 2 of 2 <12
