Home > Td5 > Help
mr_tdi82
United Kingdom 2004 Defender 90 Td5 HT Zambezi Silver
Help
Stuck in mid Wales, after driving 3/4 to snowdon, I've lost all brakes, went spongy and then lost all brakes! Went straight through a junction!. Now very scared!. Been fine up to this point. Did have new discs and pads fitted a few months ago. Ideas needed please??
Post #168719 16th Sep 2012 4:13pm
Make sure the pads are still there....... The lining can sometimes fall off.... Check all pipes for leaks whilst assistant is pressing brake, check servo area for leaks. If all these look good, it could be the ABS block (this failed on mine). QRZ 2e0vpf
Post #168720 16th Sep 2012 4:22pm
mr_tdi82
Not sure i have abs, had a good look all discs and pads look ok, master cylinder is leak free and as are the hoses/pipes and theres brake fluid, only happened after 170 miles.
Post #168724 16th Sep 2012 4:46pm
landy andy
Check the rear brake pipe that around the rear diff. If not set up correctly it wears through on the tank and Censored all the fluid out.
You can use pipe clamp or mole grips on the flex pipe from chassis to axle to get you safe.
Andy
Post #168725 16th Sep 2012 4:48pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
any luck mate
Post #168738 16th Sep 2012 6:33pm
Gareth
If there is no brake fluid loss, and the master cylinder reservoir is still full, then I would say its an internal leak past the piston in the master cylinder. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #168750 16th Sep 2012 7:46pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Servo failure? BM52
Post #168761 16th Sep 2012 8:02pm
df1
Is your brake pedal going to the floor ?
Post #168793 16th Sep 2012 9:22pm
mr_tdi82
Ok so very nice man from rac came spent sometime going all over it. After jacking it up and spinning the wheels, checking pipes etc, found slight leak from drivers rear hub seal leaking onto the caliper? Then found drivers side front wheel was slightly tighter when spinning it, so he took the wheel off stripped the brake pads out and found that the pistons coming through the caliper were quite pitted and rusted and were sticking. So he rubbed the down and cleaned them up. They moved much more freely, and so after testing it round the car park . I drove the rest of the way to Criccieth All be it much slower.
Post #168798 16th Sep 2012 9:52pm
mr_tdi82
Garage found no fault with it. Suspect servo master cylinder glazed pads?? Gonna get our mechanic to check it over when im home
Post #169008 17th Sep 2012 9:54pm
mr_tdi82
currently in berkshire land rover, servo was doing nothing- no pressure at all, master cylinder has leak at bottom, fuel pressure reg is leaking, the list goes on, and i thought it was quite reliable!. fixing it is breaking my little bank!
Post #171594 28th Sep 2012 3:38pm
T1G UP
BLR?!
ummm
Post #171598 28th Sep 2012 3:52pm
mr_tdi82
whats ummm mean't to mean, last indy garage i took it to said all my discs were shot, (they weren't) thought i'd take a leap of faith and try again, as our mechanic is too busy and needed a special tool for the brakes last time. what experience have YOU had with them?
Post #171604 28th Sep 2012 4:20pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Best of luck I got to fix a truck after they 'sorted the brakes' it came away with different sized calipers on it!
I use fw4x4 in Wattlington great quality of work at a reasonable price.
Jason
Post #171617 28th Sep 2012 5:58pm
