![]() | Home > Maintenance & Modifications > 265/75/16 or 255/85/16 on 110 |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
255.85 they aren't as wide so stop the muck being thrown so much up the sides
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Stating the obvious, but 255/85/16 are a larger diameter than 265/75/16. Therefore your gears will all be higher (by about 5%), but your speedo won't read any different. Should probably make it read correctly, as they over-read normally.
Mariol66 Member Since: 09 Jun 2012 Location: Perpignan Posts: 35 ![]() ![]() |
The 255/85/16 do not render the TD5 too winded?
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
We have 255/85/16 BFG M/T on both a 300 TDi and TD4 110
![]() Brendan |
You mean can it cope with the larger tyres? It should be fine as long as you have the standard 1.44:1 transfer box in. The gears are pretty low anyway.
Yes I have standart transfert gear box, have you got some pics with 255/85/16 on 110 please ?
Not on mine yet, should be in a few months once I've worn these Grabbers out.... (skid)
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
This Has sort of been covered here so this might be of some help mate
![]() http://defender2.net/forum/topic14517.html |
This is the fcx 130 on 255/85/16 BFG MT KM2's
We have the 130 with BFG's on and the 110 and 90 both have Cooper STT's - I like both tyres equally and would be happy to recommend either. The TD5 130 pulls fine with the taller tyre however it does have a Stage 2 kit from Alive ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
DavidITGuru Member Since: 16 Aug 2011 Location: London Posts: 99 ![]() ![]() ![]() |
Here's mine on 255/85/16 KM2s. I believe there are spacers on it though so I do get muck spraying the body. The one time I washed it, it was dirty 100m from the exit of the car wash.
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
I'm thinking of possibly this size tyres on my 90 when I change, are there any clearance issues with standard suspension? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
![]() Click image to enlarge This is "Zee-Rover" with BFG AT 265/75/16 on Zu rims. Indeed muck is prayed on the body, but I don't care very much about that. I think I'll switch to 255/85/16 when I need new tyres. Otherwise I'm very happy with the tyres and rims. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thank's, finnaly i will buy bf goodrich 255/85/16
pics please |
