Home > Camping, Caravanning and Holidays > Campmor Safari Tent |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
Anyone got any experience of these tents? looking for a good quality quick tent
25th Sep 2012 8:06pm |
Tarrel Member Since: 21 Sep 2012 Location: Ross-shire, Scotland Posts: 94 |
Not had hands-on experience of pitching or sleeping in one, but I have had a very good look round one in a South African outdoor shop. Seemed very robust. Typical South Africa safari dome tent; spring-linked steel poles, good quality polyester canvas (similar to Oztent fabric), nice chunky zips, robust ground sheet.
If you're used to nylon / polyester tents, the experience of sleeping under polyester canvas will blow you away. Quieter in the rain, darker in light mornings, and more breathable giving a better atmosphere and less condensation. HTH. 2012 Defender Utility Wagon 1981 SIII 88 inch SW Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk |
26th Sep 2012 9:15pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 711 |
I've got a Jet tent from Brendan (Overland 4x4). Easy to set up and good quality (I think so anyway). Have used it in heavy rain, strong winds and not had a problem.
26th Sep 2012 9:41pm |
I have an Oztent RV4 plus the front and side panels. Bought it as a "second" from Boab a few years ago. TBH, I'm thinking of selling it. I'm finding it more of a pain getting it on and off the roof as I get older. I'm thinking about a Lavvu, so I can have a fire in it.
The Oztents are pricey, although I've found the quality of ours OK. We've built up our accessories over the years (tent, side panels, front panel and footprint). I priced them all up recently; over a grand's worth! I also have an Ozpig woodburner (no relation to Oztent). I picked up a natty little cranked chimney section that someone was selling at the Indoor 4x4 show in Stafford, that lets me put the stove under the awning and poke the chimney out through the side panel. 2012 Defender Utility Wagon 1981 SIII 88 inch SW Follow our blog: www.newlifeinnorthernscotland.blogspot.co.uk |
26th Sep 2012 9:42pm |
Hi Yobbie, thats interesting as it was the jettent i was interested in but we noticed the black collars on the poles had split, which at the price it is aint good. How long dose it take to pitch?
i like the idea of a tent that fits in the 110 rather than getting roof bars as you would have to with an RV 4/5 |
26th Sep 2012 9:54pm |
That was one of the main reasons for going for the Jet tent I got a F25 that fits in the back of a 90. I also have sides and front, it's only the longer poles for the sides that are too long for the back of the 90, but I have found that you can get telescopic 3 part one's to replace the 2 part OZ ones. I guess the black collars you are talking about are on the telescopic poles that hold the awning up? I've had no problems so far. It probably takes me about 10mins to set up although the last time was in Italy and I had to use a hammer to get the pegs in!
Click image to enlarge |
26th Sep 2012 10:12pm |
thanks for the info
26th Sep 2012 10:17pm |
No problem. If you are serious contact Brenden he done me a good deal.
26th Sep 2012 10:22pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
The black collars on the Oztent poles are a decrotative feature rather then a funcutional part of the pole.
Yes there has been an issue with these black collars on a recent batch of poles. When selling poles as separate items we do check the poles. If need be we will exchange the poles. Why are some of the collars cracking? I personally do not know but suspect it might have something to do either with temperature or tolerances on the pole and the collar. A few tips about Oztent poles. Drill a 6 mm hole in the rubber foot. This will allow the water to drain out, if need be also allows a squirt of WD40 into the pole. Ensure pole is dry when put away. If drying tent out after a wet period away from home, extend the poles and dry them. When positioning the poles make a 1"/25mm indentation in the ground for foot of pole to sit in. Brendan |
26th Sep 2012 10:24pm |
Ssssh you are not supposed to tell people that. Otherwise they might want a good deal On more serious note where did you get the 3 part telescopic poles from? Brendan |
26th Sep 2012 10:35pm |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Yep I have one. Cracking tent, maybe not as quick to put up as a basic Oztent but not that bad either.... See here: http://www.defender2.net/forum/topic12613-15.html |
26th Sep 2012 10:36pm |
Was just lucky, I went into a camping shop in St Austell and they had them in a box of odd bits, I'll have a look at what make they are tomorrow.
26th Sep 2012 10:41pm |
Sorry Brendan, the poles don't have any make on them.
27th Sep 2012 7:55pm |
If the three piece pole extend to 2.3m then have identified them.
All I need to do is find the importer now. Brendan |
27th Sep 2012 8:15pm |
