Home > Puma (Tdci) > Aha ahaaaaaaaaaaaaaaa, looked for...........
Page 2 of 3 <123>
dgardel
Italy
SGH wrote:
I sold one to a customer of mine and he says it will not fit...
will fit, will fit..........
I can 100% confirm!!!!
with slightly mods (to the sound proofing materials and to the rear support, using the threaded holes present and free on the engine head)....
next project, Saturday I just completed this one http://www.defender2.net/forum/topic15159.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #170436 24th Sep 2012 3:24pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Look forward to reading about the fitting and the result Thumbs Up
Post #170445 24th Sep 2012 3:40pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Will it fit my 3.2 Laughing
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #170484 24th Sep 2012 6:54pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
Steve
#iamjealous
Post #170488 24th Sep 2012 7:18pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
big steve wrote:
Will it fit my 3.2
You don't want to quieten that down, you want to be running the exhaust through the cab to get closer to the noise!
Post #170510 24th Sep 2012 8:18pm
big steve
Your right but if it did fit nobody would know ts a 3.2 Thumbs Up
Post #170521 24th Sep 2012 8:40pm
big steve
Post #170522 24th Sep 2012 8:41pm
big steve
How much is that cover ? Steve 2015 2.2 tdci hardtop xs
Post #171128 26th Sep 2012 9:00pm
MartinK
dgardel - did anyone ever manage this...I prefer this idea to the noisekiller blanket....but only if it works!
Mine's mostly soundproofed now anyway, but if this delivers more benefit, I would be keen to ket one ordered & installed.
Does anyone know the Part # and price? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #232247 2nd May 2013 3:31pm
jwb
United States
dgardel (or anyone else who made this work),
I'd be very interested in what mods you made to the 2.2L cover & sound proofing materials.
I bought the 2.2L cover and made an initial effort at trimming but the fit is still not good. 3 areas that need modification: The plastic cover, the underlying sound proofing material, and something to secure the rear of the cover to the engine (no rubber "arm" like on the back of the 2.4L cover). In my initial fitment, it was hard to tell whether the obstructions were from the plastic cover or sound proofing material, or both…it was both.
- So I separated the sound proofing material from the cover (figured I could glue it back if needed), then put only the plastic cover on the engine and trimmed it to clear the various bits. There were probably 8 places that needed trimming for various lines, wiring, and the 2.4L beer holder. This was slightly tedious trial and error but fits fairly well. I may need to slightly relocate an electrical connection (or cut the cover) in the rear of the engine so it does not rub against the cover.
- With the cover piece done, I placed the bare sound proofing material on the engine, wedged various bits between fuel lines, and started to trim areas that keep it from fitting flush on the engine. Though it seems like there won't be much left of it by the time I'm done. The fuel lines and injectors do not line up well at all. If I could find a similar sound proofing material in bulk, I would just start from scratch and cut to fit.
- I've haven't yet decided how to secure the rear portion of the cover...possibly just drill a hole and cable tie it. Without more mods to the sound proofing material, the rear portion of the cover will not sit flush with the engine.
....or maybe I should just buy a NK blanket and stop fiddling with it. Smile
Any advice is appreciated. Cheers
Post #296279 6th Jan 2014 1:15pm
K9F
I 'PM'd' Dgardel about this beginning of December and he hadn't got round to fitting it then. Big Cry
"The cover is still on my Garage.....
too much busy at the moment (will be necessary to build a bracket for a "good job").....
Next spring I hope....." If you go through life with your head in the sand....all people will see is an ar5e!!
Post #296319 6th Jan 2014 3:15pm
ericvv
Post #296322 6th Jan 2014 3:21pm
Cheshire110
would be an interesting quirk to get it fitted, but don't see it making a blind bit of difference to cabin noise.
to isolate the cabin effectively it needs about 2 layers of dynamat everywhere Smile Cheers, David
Post #296335 6th Jan 2014 4:03pm
jwb
United States
K9F, thanks very much for the info! I'm not expecting magical results, but would like to tone down some of the 2.4 injector noise at the source without using a full up NK blanket. No worries if it doesn't work out.
Post #296523 7th Jan 2014 10:35am
MartinK
Part # LR029710 I believe?
Around Ł35 for a "new" one at the dealer... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #297202 9th Jan 2014 3:55pm
Page 2 of 3 <123>
