Home > Puma (Tdci) > MT82 Gearbox Breather
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
Does anyone know how the gearbox breather on a puma defender is connected at both ends? Also is it possible to remove and refit without taking the box out?
Thanks in advance,
Mark
Post #169527 20th Sep 2012 11:08am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Erm it won't be easy but on a defender it is about 8-10 inch long and at the closest point to the engine it just pushes into a hole so it breathes into the bell housing
On the gearbox I'm using with my 3.2 engine it came with a breather from the gearbox that goes straight up to the. Front of he engine
I think if you can do it which you can I managed to before pull it out from the hole and uses a 6mm connector and make it longer Thumbs Up
If that's what your intentions are
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #169533 20th Sep 2012 12:06pm
vaucluse
Thanks Steve - any ideas about how the other end is attached? And could I get in there to remove it and refit later?
I need to check it's not blocked as I have oil blowing by the filler plug. (I have the correct amount of oil)
Thanks
Mark
Post #169539 20th Sep 2012 1:23pm
big steve
Yerflat blade screwdriver under the black part and gently prize it out doubt it will be easy whilst it's in but should be possible Thumbs Up
Post #169540 20th Sep 2012 1:24pm
MK
I posted a pic showing it. Try the search button. Puma 110" SW
Post #169550 20th Sep 2012 3:36pm
vaucluse
Hi MK,
Tried a search but no luck. Can you give me the title of the thread you're referring to? Or a link?
Many thanks,
Mark
Post #169558 20th Sep 2012 4:25pm
dgardel
Italy
Item nr. 6
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #169562 20th Sep 2012 5:16pm
