Home > Technical > DIM DIP
foxkilla
United Kingdom 2008 Defender 110 Puma 2.4 USW Auto Tonga Green
DIM DIP
Can anyone help me, I wish to disable the dim dip function on my 2008 puma defender.
Post #16891 19th Oct 2009 5:57pm
Grockle
Re: DIM DIP
I think the resistor is located on the bulkhead. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #16925 20th Oct 2009 9:52am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
they don't have dim dip since certain e.u laws.
Post #16936 20th Oct 2009 2:06pm
Grockle
Commercials do 2.4 90 XS
Post #16937 20th Oct 2009 2:25pm
nicks
i've not seen that - i stand corrected. is the loom there on all models?
Post #16938 20th Oct 2009 2:29pm
foxkilla
So all I have to do is find the resistor and disconnect the wires then?
Post #16939 20th Oct 2009 2:31pm
nicks
apparently so. i have one of the resistors, i was going to fit it to mine. why do you want to disconnect it?
Post #16940 20th Oct 2009 2:34pm
foxkilla
I do not want to use dim dip.
I would prefer to have side lights only on certain occasions.
Post #16941 20th Oct 2009 2:43pm
nicks
looking in my ws manual the resistor is under bonnet rh inner fender
Post #16942 20th Oct 2009 2:48pm
foxkilla
Thank you , I will try and find it when it stops raining. Cool
Post #16943 20th Oct 2009 2:54pm
foxkilla
OK problem is solved, just cut the brown wire with green trace at side of multiplug r/o brake servo.
no more dim dip Smile
Post #16988 21st Oct 2009 2:16pm
Grockle
Thumbs Up 2.4 90 XS
Post #16989 21st Oct 2009 4:09pm
You'll find that you could have just unplugged it from the resistor pack, save cutting the loom.
I'd tape the end of the cable up too, as that'll have 12v on it when the lights are on... you don't want that flapping about under the bonnet Shocked
Post #16993 21st Oct 2009 5:41pm
foxkilla
Naturally the ends have been taped and sealed back into the loom.
It was easiest to cut wire as i could not get to resistor.
Post #16995 21st Oct 2009 6:07pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
AHA! I've often wondered about this! Think I'll give it a go myself with mine, always preferred the look of them with just the side lights on. Looks like it has a dodgy earth or something at the moment.
Cheers!
Post #17000 21st Oct 2009 6:56pm
