Home > For Sale & Wanted > Super Winch 15500 lb
D3DAN
For Sale as new, surplus to requirements
£450 + postage
Superwinch Tiger Shark 15,500 lbs (7,031 kg) 12v
Here is what separates the Tiger Shark Series apart from the pretenders:
15500 lbs of Rated Line Pull-Built to bite almost any application
Weather Sealed 5.7 HP motor-Reduces damage from rain, snow and blowing dust
Heavy-Duty 4-Stage Gearbox-Handles stress and torque on demand
Heavy-Duty Drum Supports-Load tested all the way to stall
Weather Sealed Solenoids-Reduces damage from rain, snow and blowing dust
Severe-Duty Textured Finish-Resists harsh outdoor and off-road abuse
Heavy-Duty Rubber Hand-held Remote-Field proven design provides effortless switching
Stainless Steel Tie Bars and Hardware-Great appearance & resists damage from rain and snow
Heavy-Duty Fairlead with Stainless Steel Rollers-Brushed finish endures weather and wire rope abuse
Ergonomically Shaped Freespool Control-Easy to grip and effortless to operate.
Specifications
Rated Line Pull 15,500 lbs (7031 kg)
Motor Sealed 5.7 HP Series Wound
Gearing 4-Stage Planetary
Gear Ratio 518:1
Solenoid Weather Sealed Solenoid and Circuit Breaker Protected
Clutch Free-Spooling, Pull and Turn
Brake Mechanical, Automatic Load Holding
Rope Wire 29/64" x 92' (11.5mm x 28m)
Hook Heavy Duty Clevis Pinned Latched
Fairlead Heavy-Duty, Stainless Steel 4-Way Roller
Remote 12' Rubber Hand-held
Dimensions 23.6" L x 8.4" W x 11" H (601.5mm L x 214.5mm W x 279.5mm H
Drum Diameter 3.5" (89 mm)
Drum Length 8.7" (220 mm)
Installed Weight 140 lbs. (63.5 kg)
Shipping Weight 144 lbs (65kg)
Warranty Limited 1 Year Warranty
Line PUll: 0 lbs (0 kgs) 120 Amps Motor Draw/11 FPM (3.4 MPM) Line Speed
Line PUll: 15,500 lbs (7,031 kgs) 440 Amps Motor Draw/3.5 FPM (1 M/M) Line Speed
Post #168524 15th Sep 2012 8:12am
