Home > Technical > Handbrake
rangra
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
Handbrake
Our handbrake seems to need to pull up a lot further than I would think it should in order to hold the car (about 8 inches-surely it should be less?) Its a Puma, but I guess the Td5 has the same handbrake.
Also, on a steep hill near where we live the car starts to roll down the hill (or kind of 'shudder' down the hill) when you put the clutch in. This doesn't seem right considering the fact that the transmission is supposed to be locked. Any ideas?
Thanks guys! LAND ROVER DEFENDER 110 XS SW 2.4
Post #16823 17th Oct 2009 9:48pm
Adjust the handbrake.
you can either do it from underneath, or "up top"
if underneath, then park on level ground, chock the wheels. loosen the 19mm nut on the back of the handbrake lever (there's 2, one each side of the bracket) and wind them both "in" a bit, a couple of turns should do it. nip them up, jump in the cab and see how it feels.
repeat as necessary
from "up top", remove middle seat/cubby box, remove 4 screws that hold down the lid. lean in, loosen the lock nuts..... (then same as above)
The shuddering is the shoes slipping in the drum.
normally 3 to 5 clicks of the handbrake ratchet is normal.
Post #16827 17th Oct 2009 10:22pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Get the dealer to do it simples Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #16829 17th Oct 2009 10:34pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i've noticed and at first thought it was a problem that once the hand brake is on if you dip the clutch the vehical moves back an inch or two (if your on a hill) i then realised that this was due to some slack in the drive train (normal) as the hand brake is not locking the rear wheels as in normal cars and this results in a little movement.
Post #16866 18th Oct 2009 11:30pm
rangra
Hi, I know about the lurch forward/backwards depending which way your facing. The problem with ours is that it just keeps on rolling! LAND ROVER DEFENDER 110 XS SW 2.4
Post #16882 19th Oct 2009 4:39pm
mse
All handbrakes should operate around 3 clicks...ours used to at 2 until it went for a new clutch now its 3 Mike
Post #16899 19th Oct 2009 7:21pm
double cab happy
I should have said that i also had my hand brake become less afective then found out that there was an oil leak into the drum from the prop shaft seal.
Post #16945 20th Oct 2009 3:11pm
rangra
I'll have a look Thumbs Up LAND ROVER DEFENDER 110 XS SW 2.4
Post #16946 20th Oct 2009 5:15pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Supposedly, when operating correctly, the transmission brake should operate effectively on the 3rd click.
However, Defender transmission brakes are renowned for not being reliable - mainly because, off road, they fill up the drums with crud and don't hold. If you spend any time with a long suffering owner or instructor, they'll tell you to always leave it in gear on any incline greater than a gentle slope.
Solution: fit an X-brake from x-eng or leave it in gear. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #17071 22nd Oct 2009 10:45pm
mse
Or drill a 2 small holes and anything that goes in drains out Mike
Post #17079 22nd Oct 2009 11:45pm
rangra
I left the LR outside yesterday (I usually put it inside in case somebody tries to nick it!) and this morning the car was obviously quite cold. Strangely, the handbrake now operates at about 3-4 clicks, instead of 5-6. It;s been the same all day.
This kind of thing always happens just as you have booked it in to a dealer. I booked it in for something or other (the clutch, I think) about a year ago, and as soon as it comes round to taking it back to them the problem seems to magically disapear, only to return as soon as you get back home!
Question LAND ROVER DEFENDER 110 XS SW 2.4
Post #17105 23rd Oct 2009 5:30pm
