Home > Technical > td5 alarm
markhorner
United Kingdom 2003 Defender 90 Td5 CSW Bonatti Grey
td5 alarm
Hi guys, I know you all have a wealth of knowledge on Land Rover and would love some advice. I have a Defender td5 on a 03 platea and the alarm goes off randomly like once every few weeks. This does not appear to happen when I use the key only , I understand the ultrasonic sensor is disabled internally when using the key only. Any advice please
Post #168142 13th Sep 2012 6:41pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Hi Mark,
When you set the alarm does the red light on the dash flash once every couple of seconds or many times (fast flashing)?
Post #168144 13th Sep 2012 6:51pm
markhorner
From previous inspection it flashes once every second maybe a touch longer. When closing with the key the light takes some time before it flashes.
Post #168145 13th Sep 2012 7:00pm
markhorner
Post #168147 13th Sep 2012 7:06pm
Killer90
Site Sponsor
ive seen a few with the same problem get it plugged in at a garage on the computer it will tell you the fault, my guess is the interior alarm sensor get them to delete the fault Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #168189 13th Sep 2012 8:34pm
markhorner
Thanks for the advice. Does anyone know the data protocol for Land Rover such as OBD2 for example. I know a few guys with various code readers. Times like these the old Hawkeye comes in useful : )
Post #168190 13th Sep 2012 8:38pm
check for spiders in the truck ... them walking over the sensor will make it go off Thumbs Up
Post #168248 13th Sep 2012 10:33pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
If it goes off often enough to be able to tell, just unplug the ultrasonic sensor for a night or two - if it doesn't go off you know it's that that's being triggered. Only takes a couple of minutes to do, pull the sensor out (it's only held in with spring clips) and unplug the connector on the back of it. http://www.yorkshireoffroadclub.net/
Post #168265 13th Sep 2012 11:34pm
TR51
^^ Thumbs Up ...
I know it's a right pain though as when mine did a similar (same) thing it only goes off pnce in a blue moon!!
Seems like your alarm+ immobaliser is setting correctly (ie no doors open+door switches working)
Post #168268 13th Sep 2012 11:56pm
Laurie
Mine did that when it rained.
Spraying the doorswitch internals with WD40 was a permanent cure.
Post #168271 14th Sep 2012 12:53am
it's also possible to electronically switch the sensor off using a nanocom
Post #168289 14th Sep 2012 7:21am
And to adjust the sensitivity of it.
Post #168295 14th Sep 2012 7:39am
markhorner
Great advice guys, I appreciate it. Bow down Think I may invest in a nanocom Thumbs Up
Post #168460 14th Sep 2012 9:10pm
davew
A quick word of warning/heads up
I have a Nanocom, best thing you can do before you make ANY changes to the alarm or ECU settings is save the current working settings to the SD card.
I made a change to the alarm settings on mine while testing the volumetric sensor. Pam goes out to the 90 later that night and the interior lights had stopped working. Never did find out why, all the interior light settings looked fine (I hadn't touched them anyway) but restoring the alarm settings from the saved version and they started working again. lesson learned - don't **** with the alarm settings without a backup ! http://www.yorkshireoffroadclub.net/
Post #168481 14th Sep 2012 10:54pm
Laurie
Try WD40 first, it's a hell of a lot cheaper Rolling Eyes
Post #168500 15th Sep 2012 12:50am
