![]() | Home > Maintenance & Modifications > rear cross member |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Depending on the method of attachment it should be fine. It won't be as easy to do as on a clean cut chassis but should only require a little more cleaning up. |
If you need one for a TD5 give Andrew at Defenderbits (site sponsor) a call. He is selling my brand new MIB rear crossmember for me as I did not need it in the end. Good price
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
It depends on whether the one you are replacing was it's self a like for like swap of the original or not? If it was then ok, if it is a winch carrier welded just behind the rear axle for example then you can put it back to factory just fine if you are keeping the mod but with a new part you may well need an iva unless the car has one for its current configuration. Rhubarb and custard let fly with their secret weapon.
