Home > Maintenance & Modifications > Engine options?
noogles
Brunei
Engine options?
I've grown quite tired of the 2.5d na in my 110. Being in south east Asia, land rover parts shipped in can be quite expensive. What realistic options are there? I hear quite a number of people putting isuzu units in. Maybe a 3.0 turbo diesel out of a Toyota land cruiser?
Post #71098 16th May 2011 4:59am
BigMike
The isuzu engine s an easy option, fits no problem. Otherwise a 200 or 300 tdi but you may struggle to find one
Post #71114 16th May 2011 10:23am
MK
Nissan 2.7 or 3.0 are also known for a swap for landys. They should cost pennys over there. Puma 110" SW
Post #71132 16th May 2011 1:02pm
spudfan
Ireland
Land Rover used to fit an Isuzu in Australia. Seems it was very agricultural sounding but was excellent in the rough.The Perentie had an Isuzu engine also. No doubt the folks on the Australian site will have all the info you might need. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #71148 16th May 2011 3:52pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
They also fiited the BMW straight 6 petrol for South Africa so how about the BMW 330d or the 335d Very Happy
Post #71157 16th May 2011 4:23pm
noogles
Brunei
I've been asking around and the Toyota B engines seem to quite popular.
Quote:
15B-F
The 15B-F is a 4.1 L (4104 cc) inline 4 sixteen valve OHV direct injection diesel engine (same configuration as the 15B-FTE but no turbo and intercooler). Bore is 108 mm and stroke is 112 mm. Output is 115 hp (85 kW) at 3200 rpm and 214 ft·lbf (290 N·m) of torque at 2000 rpm.
[edit]15B-FT
[edit]15B-FTE
The 15B-FTE is a 4.1 L (4104 cc) inline 4 sixteen valve OHV direct injection turbo intercooled diesel engine. Bore is 108 mm and stroke is 112 mm, with a compression ratio of 17.8:1. Output is 153 hp (114 kW) at 3200 rpm with 282 ft·lbf (382 N·m) of torque at 1800 rpm.
Taken from http://en.wikipedia.org/wiki/Toyota_B_engine
The 15b turbo is/was used in the Toyota MegaCruiser
http://en.wikipedia.org/wiki/Toyota_Mega_Cruiser
Don't know how easy parts would be to get though.
Post #71253 17th May 2011 6:56am
DasLandRoverMan
1984 Defender 110 300 Tdi HT Epsom Green
The Mazda SLT was a popular fitment into V8 powered vehicles in the late 80's/early 90's before the Tdi became cheaper/more readily available.
Not many in the UK, but apparently a lot of them in Australia.
The Nissan TD33 and 4.2 Litre Toyota six cylinder diesels are also pretty formidable lumps. 1982 Wife
1984 300 Tdi 110 H/T 'Recovery'
Plus 4 kids and a dog.
Previously owned: 1956 86" Series I, 1960 SWB Series II, 1964 Series IIA Forward Control, 1966 Series IIB Forward Control, 1969 Series IIA Lightweight, 1969 Series IIA One Ton, 1973 Series III One Ton, 1975 101 Forward Control, 1987 V8 90 CSW, 1988 2.5 TD 90, 1988 V8 110 CSW, 1992 200Tdi Defender 90, 1993 V8 Range Rover, 1995 300 Tdi Discovery.
Post #72928 26th May 2011 5:35pm
jakeslouw
South Africa 1989 Defender 110 V8 Petrol CSW Alpine White
Did Noogles ever go any further with his conversion plans?
I've done a fair bit of research into replacing my 3.5 V8 with a turbo diesel, so can provide some insights.
Post #167836 12th Sep 2012 12:41pm
