Home > Puma (Tdci) > Hazard lamp light
22900013A
Hazard lamp light
Had an early start this morning so drove to work in the dark with the lights on for a change. I noticed that the hazard lamp triangle on the dash doesn't light up - is this normal or has mine blown a blub? Also, does the headlamp aim adjuster tab light up or not, as I have heard some folk say it should?
Cheers.
Post #167654 11th Sep 2012 5:09pm
spudfan
Ireland
Just checked. The warning triangle on the hazard light switch does light up. The headlight adjuster knob does not light up but the numbers on the lefthand side of it do. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #167729 11th Sep 2012 8:57pm
22900013A
Hmmph, looks like I have a blown bulb and a missing bulb then. So what do I need to get from Halfords, besides a special screwdriver to take the dash centre panel out?
Post #167754 11th Sep 2012 10:09pm
ZeDefender
Remembered this thread - may be of use:
http://www.defender2.net/forum/topic12482....zard+light
Made me run outside and check mine Laughing Tell someone you love them today because life is short.
Post #167760 11th Sep 2012 10:31pm
spudfan
Ireland
Think it one of those Torx screwdriver heads. There's a thread on this site about removing the centre dash. Once you remove the screws it's a matter of prising out the centre dash. Have not had to do it myself so hopefully someone with some experience of actually removing it will be along to give you the do's and don'ts.
Hopefully someone will tell you what bulb to get so you can have it instock before you remove the dash.
The tdi used to use small plug in type capless bulbs, 12V 3W, but I don't know about the Puma. 1982 88" 2.25 diesel
Post #167762 11th Sep 2012 10:32pm
22900013A
How funny, it has now fixed itself...typical Landrover electrics eh...
Post #168632 15th Sep 2012 9:53pm
spudfan
Ireland
Do you have to specify this optional extra? Rolling with laughter 1982 88" 2.25 diesel
Post #168676 16th Sep 2012 9:30am
ericvv
In case someone needs to buy the little bulb for this hazard lights switch, read the following which PaulMc was good enough to let me know when I had this little bulb burn out a while ago. And LR could not find the replacement for it in its database, so I ordered a few from rimmerbros. Below are the details, one day you will need them Thumbs Up
As for the switch's bulb, it's not listed in Microcat for the 2002-2006, or 2007 -> Defenders (so most dealers tell you it's not replaceable and try to get you to buy a complete new switch).
It is replaceable, it's listed for the 300Tdi Discovery 1 Hazard Warning Lights Switch (which is essentially the same switch, but vertical instead of horizontal), its part number is -
STC1205 - BULB & HOLDER ASSEMBLY, CLEAR
http://www.rimmerbros.co.uk/Item--i-STC1205 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #168683 16th Sep 2012 10:05am
22900013A
I thought it was a standard fit since at least the 1960s, my IIA has the same foible.
Post #168684 16th Sep 2012 10:10am
Merlin
Just got mine, when you say "little bulb", you're right. It's so small that for a minute I thought they had forgotton to put anything in the box.
Merlin
Post #168716 16th Sep 2012 4:03pm
