![]() | Home > Puma (Tdci) > New shocks |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
they ride alot better with weight.Try it loaded and then see. You can get air bags that assist ride height. Dampers only control the axles damping not its ride.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
Koni heavy track raids, great comfort, I often drive heavily loaded and tow to the max, others on here recommend Bilsteins too - any decent quality shock will give noticeable improvement.
Also consider poly bushes, they help too. Keith |
doberman Member Since: 05 Aug 2012 Location: Cambridgeshire Posts: 53 ![]() ![]() ![]() |
I totally agree it drives far better loaded,it's a horrible ride empty it's just I was wondering if a good quility set would be much better than standard the ones, I forgot to mention I've got a full roofrack as well adding to the weight
Bilsteins will help and make the ride so much smother.....had mine on for over 3 years with no problems...... standard shocks are
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8397 ![]() ![]() ![]() |
OME work well in my experience
Koni as aforementioned are good but £££ and didnt always last in my experience King i am currently experimenting with - very good to date but quite £££ Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Koni heavy track raids then anyting else Koni , then billies, Land Rover, last yellow Monroes.
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Those Konis get my vote |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Bilsteins get my vote...
And I can supply them at a good price ![]() Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
I put Bilsteins on in Feb 2012, very happy with the on- and off-road performance, although we only did 2 mild trails.
Recently there was a rattling noise from the back, my indie had a look and found the rear left shock's cover was loose. Upon closer inspection it turned out the shaft itself was moving, so had to send it back to the distributor. Still waiting for their answer. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bvandyk Member Since: 03 Sep 2012 Location: South Africa Posts: 49 ![]() |
I'm running Terrafirma ProSport shocks. Happy with it
![]() Go for the Terrafirma heavy duty coils, as the medium coils tend to sag under heavy (over) loaded conditions. |
