Home > Technical > which radiator
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
which radiator
Hi all,
I have a 110 with a retrofitted Td5 engine. The rad has sprung a leak, but I don't know which one I need. The part number is PCC001010 but paddocks shows a "to" and "from" chassis number so any idea which one I need.
Strangely, John Craddocks shows one fits all.
Any advice?
Dave
Post #167222 9th Sep 2012 10:11pm
K9F
http://www.defender2.net/forum/topic14428.html?highlight=radiator If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167225 9th Sep 2012 10:22pm
v8bobber
Didn't really answer my query unfortunately
I just need to know which one I need to get
Dave
Post #167226 9th Sep 2012 10:29pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Looking at those chassis numbers, I would think it's the cut-off between EU2 and EU3 vehicles, i.e. when they changed the injection pressure, put a cat on and a few other bits. I think the easiest way to tell is to see how many actuators are on your EGR valve - 1 actuator it's the older version, 2 actuators it's the newer one. Although it depends how complete your engine retrofit was - i.e. were all the ancillaries transplanted too. Only you know how old the engine is.
A word of warning though - I put a Paddocks radiator in my old Td5 and it started leaking after 6 months Evil or Very Mad
Post #167227 9th Sep 2012 10:36pm
v8bobber
I was thinking the same thing,
I thought that it might be something to do with having a fuel cooler, which mine has. It's a pain in the backside not having the correct chassis number. If I could work out what the differences were between the two radiators then at least I could compare it to whats in there at the moment.
Dave
Post #167231 9th Sep 2012 10:42pm
T1G UP
get the early one. http://www.landyspareparts.com/cooling-system-radiator-299-p.asp
Post #167232 9th Sep 2012 10:44pm
v8bobber
T1G UP wrote:
get the early one.
lol. any reason for that statement?
Post #167233 9th Sep 2012 10:45pm
T1G UP
v8bobber wrote:
T1G UP wrote:
get the early one.
i think there both the same tbh. having had an early td5 90 into which i fitted a later engine the rad stayed the same
Post #167234 9th Sep 2012 10:47pm
walfy
If your rad has sprung a leak, why not get it recored? When my 300TDI rad needed renewing it was cheaper for an uprated recore rather than a new rad from all the usual suspects. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #167249 10th Sep 2012 5:58am
K9F
v8bobber wrote:
Didn't really answer my query unfortunately I just need to know which one I need to get Dave
Re-coring was mentioned as a suggestion in the link I posted too. Walfy's right! Be cheaper than a new rad and you'd not have compatability issues with fitment.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #167267 10th Sep 2012 8:14am
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
In process of fitting new rad from Craddock who said there was only one. Mine is 03 td5 90. Was nervous as I'd been told that there were two and my car is on the change date!! New one is identical to old so ok.
Post #169068 18th Sep 2012 2:53pm
