![]() | Home > Technical > Help amd advice on MOT adviosory notes |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17980 ![]() ![]() ![]() |
Brake anti slip is probably the rubber pad on the brake pedal. Not a big repair but may be indicative of high mileage.
As far as I know neither of these would be grounds for failure. |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
brake pedal rubber...stupid bloody advisory.
dampness...what on a landrover! Never ![]() |
Davey
welcome to the forum ![]() 57 plate was the first year of the puma/tdci models, there were a few "teething" problems with the new model but with 72k they should have all been sorted out. before you buy: have a good look underneath for anything loose, leaking or bent, check under the carpets front, middle and rear - make sure it's all dry (it should not smell like a dogs bed inside). Check the colour of the oil, check power steering fluid and coolant levels - thses should all be fine, but if not, maybe there's been some skimping on servicing. when you drive and brake, it should not pull in either direction, test hi/low & difflock (on grass / gravel). Overall, the 2007-on is a great truck, 6 gears, heater that works etc. expect a suprise from time to time, either get a good warranty or save a little each month. good luck |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
IIRC there was a recall for the transfer box output shaft seal which if it fails can cause contamination of the transmission brake. Armed with the VIN number your friendly local dealer should be able to look up what recalls and warranty work have been carried out. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Davey Member Since: 08 Sep 2012 Location: Norfolk Posts: 2 ![]() ![]() |
Thanks everyone for your comments - I'll probably be back here soon!
Cheers ![]() |
