![]() | Home > Maintenance & Modifications > Steering Guard |
derek Member Since: 13 Jan 2012 Location: Beckenham kent Posts: 94 ![]() ![]() ![]() |
Just fitted a First Four steering guard
![]() Click image to enlarge ![]() Click image to enlarge[/img] |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Looks good, got one like that on my old 90 (Paddocks I think) with the same holes and towing eyes, been thinking of that for the 110. Looks a bit shinier than the Paddocks version though.
![]() Nice to see nicely aligned wings, mine need a bit or straightening up at some point. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Thanks It's the Shadow Aluminium guard £107.34 inc vat ordered online arrived next day.
It's got galvanised steel side panels with 10mm Alu main plate |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
Looks very good. I might bump into you, you're just down the road.
cool I drove to work to fit it only took 40 mins to fit, what colour is your defender
Silver.
nice black shows every bit of dirt
yes they are 10mm galvanised steel part of the side plates only the base plate is laser cut 10mm aluminium
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
Should be able to take bit of a pull then. I've got the KBX black grille so may spray it black, but can have a look see first if it's so easy to fit. 90 XS
Volvo V70 |
Have got to fit my stainless steel headlamp rims next
Got from mobile centre |
Yeh, another thing that's on my list of to-do's. Mine are rusty as hell when you take a close up look. 90 XS
Volvo V70 |
Will look good and match the intercooler grille. ![]() Treat every day as if it is your last....one day you will be right!! |
Mine are a bit too but 5 years old, just had a service and the courtesy defender also 5 years old were much worse than mine but it had done twice the milage
must get round to ordering that
